First time for everything
shedrool83
After owning e30's for longer than i care to remember i thought i had turned /pulled every bolt/clip on these things .
That was until today i done two jobs i have never done before in my life .
1st was to swap the passenger seat runners and 2nd was to clean the track on the afm actually enjoyed learning today.
Name a job you have done e30 wise and actually enjoyed the experience .
Satan
Filling it with fuel, for a trip thats about it........... ;o))))))
shedrool83
Cloggy Saint
Satan
Mines fine........ ;o))))shedrool83 wrote: ↑Sat May 30, 2020 3:44 pmGood chance if you fill any e30 and haven't changed the tank that would be a bad experience Hahaha
BristolE30
Swapped out the injectors with new ones a few months ago that was very satisfying and surprisingly not too painful
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
coopman
I think the only job which went completely smoothly and had a good outcome was replacing weather strips. Changing the old odometer gears was also quite enjoyable. Everything else has been a massive pain.
shedrool83
I want to to this to,BristolE30 wrote: ↑Sat May 30, 2020 10:58 pmSwapped out the injectors with new ones a few months ago that was very satisfying and surprisingly not too painful
Did you get yours reconditioned or buy new?
rix313
I changed the crank seal on one the other day. One of my fingers still bares the scars but I actually didn’t mind it although not in a hurray to do it again haha.
steve_k
out of all the jobs i've learnt to do on my e30 while i've had it the one i enjoyed doing the most was building my 2.7 m20, i'd never done one before so it was a steep learning curve, but i have to say that i enjoyed that the most.
would i do it again? probably.
Satan
InjectorTune on here will clean and refurb injectors if you don't need the car for a week.shedrool83 wrote: ↑Sun May 31, 2020 5:10 amI want to to this to,BristolE30 wrote: ↑Sat May 30, 2020 10:58 pmSwapped out the injectors with new ones a few months ago that was very satisfying and surprisingly not too painful
shedrool83
Satan wrote: ↑Sun May 31, 2020 11:29 amInjectorTune on here will clean and refurb injectors if you don't need the car for a week.shedrool83 wrote: ↑Sun May 31, 2020 5:10 amI want to to this to,BristolE30 wrote: ↑Sat May 30, 2020 10:58 pmSwapped out the injectors with new ones a few months ago that was very satisfying and surprisingly not too painful
BristolE30
I bought new! At the time the Bosch ones were only about £25 each from a random parts website, they had x4 in stock - then another X2 I got shipped from USA through amazon. After I bought them they suddenly rocketed to about £45 each.shedrool83 wrote: ↑Sun May 31, 2020 5:10 amI want to to this to,BristolE30 wrote: ↑Sat May 30, 2020 10:58 pmSwapped out the injectors with new ones a few months ago that was very satisfying and surprisingly not too painful
They may have done another production run now though so might be a bit cheaper. It was like £25 new or £20 refurbed, so I just went new
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
BristolE30
Here’s the link for them on amazon I used. £27 for brand new... guess you gotta weigh it up! I always like to buy new for peace of mind
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
Satan
I paid less than £80 I believe for 6 (Zone Discount) plus postage to send them.BristolE30 wrote: ↑Sun May 31, 2020 1:24 pmI bought new! At the time the Bosch ones were only about £25 each from a random parts website, they had x4 in stock - then another X2 I got shipped from USA through amazon. After I bought them they suddenly rocketed to about £45 each.shedrool83 wrote: ↑Sun May 31, 2020 5:10 amI want to to this to,BristolE30 wrote: ↑Sat May 30, 2020 10:58 pmSwapped out the injectors with new ones a few months ago that was very satisfying and surprisingly not too painful
minesapint
I paid £82 a couple of years back to Injectortune. A great service, they are as new when returned with new spacers, pintle caps, o-rings, & filters.
But interestingly comes a report with refurbished injectors giving info on.......
Resistance test
Leak test
Spray pattern
Static flow test both before and after cleaning.
So you know how good or badly they were performing prior to refurbishment.
Resistance test
Leak test
Spray pattern
minesapint
I recently took out my heater blower motor, as the bearings were starting to ‘squeak’.
Not a difficult job, but working on a part of the car one doesn’t normally go into or see.
BristolE30
I need to do this!! Mine is so squeaky in settings 1 and 2minesapint wrote: ↑Mon Jun 01, 2020 1:13 amI recently took out my heater blower motor, as the bearings were starting to ‘squeak’.
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
