Anyone who has had mtec rust woes......
OllieB
Post Sun Feb 05, 2006 4:49 pm
......was it as bad as you originally thought? Did you get it sorted? HOW MUCH DID IT COST!!
Just been cleaning my car, which is a G-plate sport. Found a big rust bubble under the black thing that holds the rear numberplate on where it is screwed in. This is not the end of the world as far as I know because while it looks horrible it is only the size of an old 50p and can probably be sorted easily enough. Whilst checking round at the rest of the minor rust niggles (Edge of bootlid bit scabby, tiny bit on edge of drivers door etc) I found some dreaded rot under the kit. It is on the offside rear wheel arch, nearest the door, and the bottom rivet is loose because where it should be screwed in is rotten. I did the obvious thing, curled up on the drive in the foetal position and sobbed for a bit. I need you to regale me with tales of your mtec rust woes so I can feel a bit less bad and know that it is not the end.
:cry:
I'm too scared to drift properly......
Post Sun Feb 05, 2006 5:38 pm
ahh another discovers what we all preach! All sports rust under the kit, it's a sad fact about them.
Whip it all off and have a good look.
Hence theres no such thing as a mint sport now! They all need welding at some point! :D
Simon
Post Sun Feb 05, 2006 8:04 pm
The car I have as a track car had an M-tech II kit, it had been fitted since 1989, and has 153k on the clock, and no rust under the kit...plenty of it elsewhere though!! Under the fusebox, and arches, but at the top of the arch!
Simon
Post Sun Feb 05, 2006 8:07 pm
Just found these pics...
parksie
Post Sun Feb 05, 2006 9:02 pm
You truly have to remove all m tec panels :o , then the truth will be revealled 8O
Mine required.
New rear panel
rear arch replacement
internal sill welding
New front wings
New sunroof panel
Boot floor under battery replaced
Scuttle panel repair both sides
Full body respray
No change from Ԛ£2k, but it was worth it to me, i now have the knowledge that every corner , nuck & cranny has been inspected & repaired.
Good luck with yours
Post Sun Feb 05, 2006 11:36 pm
theres always one,
mines goona need,
a bit on scuttle
new sunroof
2 new wings
front floor pans welding
rear arches both sides
boot bit there too
and some on rear panel
Sills seem solid
I'm hoping i'll do this when it comes off the road in the next week or so for the 2.7 also. Do it all in one go, i can see it being off the road for a year or so! Money,money,money :?
fez
Post Sun Feb 05, 2006 11:40 pm
Both my rear arches are corroded straight through and are gonna need replacing. Any idea what a "Reasonable" price would be to get them replaced?
<html><A>
<img> </A></html>
Post Sun Feb 05, 2006 11:48 pm
Naylor had his arches done on his sport for Ԛ£450 which seems reasonable to me for the work involved. It looked a top job too and his arches were bad!
bigun
Post Mon Feb 06, 2006 7:01 am
yeah looks like i need the usual
2 front wings
back panel
sunroof panel
repair to scuttle
repair rear arches
and repair a shoddy job on the front panel
i will start this work when i have finished re building my engine boy its hard running a house re building a car and a job where im on 24hr call out :clin:
fez
Post Tue Feb 07, 2006 4:54 pm
Hey Simon13, did naylor get both arches replaced for Ԛ£450 or was it just welded? i got a quote to get bot inner arches replaced for Ԛ£800 or just cut out and welded for Ԛ£300. to me it sounds really steep but all the garages ive been to have said its a big job and thats why it'll cost so much. cheers for your help.
<html><A>
<img> </A></html>
Post Tue Feb 07, 2006 11:32 pm
tbh honest i can't remember i think they were just repaired and blown in, but don't quote me
In all honesty i'm thinking of finding a very good 318is shell and re shelling mine, all i would have to is get my M-tech kit sprayed to match.
better than the heart ache of getting it all repaired and done and then finding later on it's coming back. Plus it could work out cheaper long term, depending on how much of the work u could do yourself
oguz327
Captain Armco
Captain Armco
Post Wed Feb 08, 2006 12:45 am
Simon13 wrote:tbh honest i can't remember i think they were just repaired and blown in, but don't quote me
Ive been thinking the same thing, mine has rust in all the above areas but there not really visable cosmetictly exept for the roof which has already been done twice and came back through in six months :cry:
Would be really costly to have it all done properly.
Trouble is mines a tech 1 so finding a mint crome bumper shell is going to be well tricky
Dan318-is
Post Wed Feb 08, 2006 1:31 am
You cannot sacrifice an IS like this surely! what would happen to all the running gear?
Kos
Post Wed Feb 08, 2006 1:36 am
bollocks to that simon !!!
the car would never be a genuine sport again.
Kos
Post Wed Feb 08, 2006 1:38 am
fuck the IS dan, as long as mine and yours are ok, makes them go up in value a little more each time one gets scraped, with the last few i've seen go recently i recon mine gone up a tad!!!
Dan318-is
Post Wed Feb 08, 2006 10:06 am
Dude there has been about 4 this weekend!
let alone the 8 or 9 or so in the last month or two its insanity i tell you
more spares i guess!
Post Wed Feb 08, 2006 4:53 pm
As long as they cylinder heads keep cracking on 318iS they will continue to die!
jaistanley
Post Thu Feb 09, 2006 6:48 pm
I'm glad I dont have an M Tech kit then! My 318is is pretty much solid with only minor surface scab on leading edge of bonnet and the now dead door:
I have the joy of having to replace drivers door, outer sill beneath it, the little outer one behind that and have to pull/fill/paint the bottom of the B panel.
Some dumb bitch drove into me on a roundabout!
GRRRRRRRRRRRRR.
Seems like the perfect time to fit a full M Tech kit then.. Cover all sins. Plus the M Tech II cars look excellent in shiny spec, Brilliant Red.. winkeye
Jai
