Under body heat shield
paultv
Post Wed Feb 26, 2020 8:55 am
I'm looking for a replacement heat shield 51481932391 for the cabby.
I've found one or two but they are different part numbers and apparently don't fit the vert,
Anyone know what the difference is between a standard E30 saloon, a touring and the cabby versions of these shields - they all "look" the same
but maybe I'm missing something.
Paul :-)
paultv
Post Wed Feb 26, 2020 9:17 am
Oh right - maybe I can answer my own question!
The cabby has an extra cross member under the tunnel, so the heat shield is shaped to accomodate this.
Paul :-)
TurtleDesignTech
Post Tue Mar 03, 2020 6:05 pm
Good job Paul :clap:
Post Wed Mar 04, 2020 8:24 am
The cabby heat shield is steel rather than aluminium, its about 10 times heavier and forms part of the body structure
paultv
Post Wed Mar 04, 2020 6:16 pm
Thanks for that..I knew someone would have a precise answer...yes mine is heavy- weight steel....so I think it might be an electroplate job...to get it rust free and shiny!!
Paul :-)
twenty
Post Sun Aug 30, 2020 11:14 am
Did you manage to find one at the end? I'm also in the lookut for one.
Paul :-)
paultv
Post Sun Aug 30, 2020 2:37 pm
I found a couple second hand but as bad as mine really - so I cleaned mine up and painted it with High Temp spray - I guess one day I'll build a giant zinc plating bath.... winkeye winkeye
Paul :-)
twenty
Post Sun Aug 30, 2020 3:34 pm
Paul :-)
Would appreciate any links to second hand ones as the ones on eBay currently are all non cab versions.
Thanks!
twenty
Post Thu Sep 03, 2020 11:26 am
Found a breaker who says this comes from a cabbie... yet to confirm the part no but does this look like the correct shape for a cabbie?
Thanks!
paultv
Post Sun Sep 06, 2020 12:36 pm
Looks like ally...should be clearly a galvanised finish on steel to be for the cabby.
Paul :-)
Post Sun Sep 06, 2020 1:48 pm
I had a quick zoom and its not ally, you can make out the corrosion from the steel edges near the holes, ally corrosion looks quite different.
twenty
Post Tue Sep 08, 2020 2:38 pm
I went ahread and ordered it anyway and it arrived today.
The part weights 1.3kg - not exactly very heavy? It does look like it's made from some light weight steel material and I couldn't find any part no. stampted anywhere.
minesapint
Post Tue Sep 08, 2020 8:38 pm
Get your magnet out.
twenty
Post Tue Sep 08, 2020 10:30 pm
Just had a facepalm moment.
I realised that BMWFans/ETK displays part weight too.
Seems like the cab version weights 4.1kg.
The others 1.3kg. Which is what I have. Clearly the wrong part.
Back to the drawing board...
paultv
Post Wed Sep 09, 2020 4:52 am
I also noticed the rear section is pop riveted...that must be a give away.
Paul :-)
minesapint
Post Wed Sep 09, 2020 8:11 pm
Paul :-)
I noticed the pop-riveted section too, but thought if it was galvanised steel, ideally you’d galvanise the two pieces before assembly & riveting or bolting is the only way to fix together.
psychochild187
Post Fri Sep 11, 2020 10:01 am
I feel lucky now, i had just recently had mine off the car and shot blasted and i painted it with galvanising paint, i don't like the finish . i wanted it to be properly galvanised but couldn't find anyone, so gave up.
but i now know it wasn't that easy to find a replacement either
paultv
Post Fri Sep 11, 2020 12:39 pm
I reckon these guys would do it
http://derbyplating.co.uk/
Paul :-)
