Paul
Winter Diff refurbish
paultv
Finally finished re building and re furbishing my 3:46 open diff... out with the 3:73 limited slip unit for now.
Paul
Paul
aimlessrock
that looks factory fresh..
E30 320i Convertible (1989)
190 Mercedes (1988)
190 Mercedes (1988)
paultv
I didn't take a shot of it before - it was a massive rusty rancid heap of junk!
Paul
Paul
flybynite
Did you swap the internals or just the whole unit? Just wondering if you had to do much to the preload and backlash.
paultv
I took everything out except the pinion gear - re used the same input nut/washer after having marked it's position carefully - as per Bentley - checked the pre-load - it was close to 2Kg - as the bearings have not been replaced I guess some wear would be expected - as far as I know there should be about 2.5 kg for the pre-load for new bearings.
The output bearings also remained unchanged - everything felt and looked very good - so the only thing is to mark which side is which for the bearing holders and the spacers - the gear mesh pattern looks fine both forward and reverse - in other words, on both faces of the drive gear... so although the diff was in terrible condition, all the seals, dust covers were rotted away - the internals looked very clean, quiet and no strange marks anywhere.
This is going to be my winter "autobahn" unit for some of the long drives I do in Europe - should feel a bit less busy at 140 - 160kph - with the 3:73 first is almost unusable, or at best a bit pointless unless I'm pissing around on dry backroads in the summer for fun! and being able to drive fast here, it will be good to get the revs down a bit -
Next few weeks will tell, I've got a noisy rear bearing so the back ends all coming out -
Paul
Paul
flybynite
Good work!
Let us know how you find it , I'm having a bit of back and forth over the ratio for one of mine. Only want to do it once ideally
paultv
I'm a bit mad thinking of having a swap out diff whenever I feel like a change!
Paul
Paul
Foe
Nice work Paul
paultv
Nope... but what exactly was it??
Paul
Paul
sorry,got you mixed up with someone else
+ a yard full of scrap turds
