Handbrake lever split!
paultv
Post Tue Aug 14, 2018 9:14 am
I noticed that my handbrake lever looked off center, so pulled off the covers and found it has a split half way through - never seen this before - I'm not in the habit of performing handbrake turns either.
Paul :-)
Post Tue Aug 14, 2018 9:18 am
Could have been nasty in a hill-climb or emergency situation.:eek: Good old metal fatigue, I guess...
Satan
Post Tue Aug 14, 2018 9:30 am
You pleasure yourself with your left hand and have built up some muscle it seems.........
Cloggy Saint
Post Tue Aug 14, 2018 9:33 am
I had the same on mine a couple of years ago. It's only thin metal and 30 years of being yanked will take it's toll eventually.
paultv
Post Tue Aug 14, 2018 10:12 am
So buying a second hand one will probably result in the same failure - new is pretty pricey, but then also a major safety item.
Paul :-)
Post Tue Aug 14, 2018 12:38 pm
Ive only heard of it two or three times so it could be well worth chancing a second hand one Paul.
paultv
Post Tue Aug 14, 2018 4:04 pm
Got a "chancer" off the "bay" - lets see what shape it's in, meanwhile I'm off the road!
Paul :-)
Jesus325iTouring
Frog freak !
Frog freak !
Post Wed Aug 15, 2018 7:52 am
My first E30 did that, being I was penniless at the time, I fitted a piece of tube over it, job jobbed :D
Post Thu Aug 16, 2018 1:34 pm
Rather than get the brakes to work properly, people just pull the lever harder :roll:
Satan
Post Thu Aug 16, 2018 2:26 pm
DanThe wrote:Rather than get the brakes to work properly, people just pull the lever harder :roll:
Never clean the cables up or use the adjusters under the lever cover.
Post Thu Aug 16, 2018 2:29 pm
:cool: :cool:
paultv
Post Thu Aug 16, 2018 2:56 pm
Bloomin' nightmare scenario now, getting the old cables out - found all sorts of horrendous issues with the outers, inners; no wonder the handle gave out!
Paul :-)
Post Thu Aug 16, 2018 3:54 pm
paultv wrote:Bloomin' nightmare scenario now, getting the old cables out - found all sorts of horrendous issues with the outers, inners; no wonder the handle gave out!
Paul :-)
Could be best to change the lot Paul then you know it`s all OK. ?
Black_Op_88
Post Sat Aug 18, 2018 9:29 am
This happened me during the MOT test. Failed for faulty handbrake as the button stuck up inside the sleeve. When I returned home to investigate I realised that the handbrake had broken exactly like yours Paultv. I went to a breakers and go a new one for £20. I've no idea what a new OEM one would cost. I'm sure it would get us a laugh.
paultv
Post Sat Aug 18, 2018 1:17 pm
They are 160 quid or so, I got one off the bay, it came this morning, looks in good shape for 15 euro's.
I did buy a new handle (plastic bit ) which looks the dogs, and a new gaiter which also looks great - very cheap from the BMW dealer here.
So I just have to replace the cables ( f'ing impossible ) then I'm back on the road!
Paul :-)
corkie
Post Thu Aug 30, 2018 5:26 pm
this also happened mine bought one off a zoner for a tenner !
e30
paultv
Post Mon Sep 03, 2018 7:14 pm
quick update - got the handbrake lever and new plastic handle,gaiter fitted. After many days of cursing I managed to extract the sorry remains of the old cables, mostly using brute force and a small but powerful Bosch drill.
Setting up the parking brake shoes is a bit of a pig with an LSD, hard to tell when the shoes are biting as there's so much drag - no chance to simply spin the hub.
Any road up - managed a ropy handbrake turn type event on a wet hill - so it works!
Paul :-)
