Z3 driveshafts
redcar
Post Sat May 05, 2018 5:59 pm
Does anyone know if z3 2.8 drivehsafts will just bolt in to a 325i abs rear end?
Would like ABS ring to end up in the same position laterally, don't mind if the ring isn't exactly the same thickness.
My current driveshafts aren't in great order and rather than spending money rebuilding them I'm thinking it would be easier to find a set of lower mileage, cheaper and stronger (?) z3 2.8 ones if they just bolt in.
Or even if anyone can suggest any other abs driveshafts which will work (eg. e36 compact, z3 1.8?)
Thanks for the help.
