S62 E30 parts prices??
davethegoat
Post Mon Apr 30, 2018 12:59 pm
Hi. It looks like I'll be breaking my S62 powered E30. I'd really appreciate some feedback on pricing up some the parts before I put a proper ad up and get crucified by the masses! :cry:
Either some of the parts I have are thin on the ground, or I've turned into a google dimwit. In whichever case, I'd really appreciate your help! :D
Build thread here: http://www.e30zone.net/modules.php?name ... c&t=213587
TIA! Dave.
S62 engine. Less than 200 miles since big end bearings, head gaskets and vanos seals replaced.
Cylinder heads ported, faces surface ground, valves cleaned and polished, and rebuilt.
Oil pump stripped, cleaned, inspected and rebuilt. £5950
Modified ECU. EWS delete, Alpha N, Sports mode enabled. £750
Aeromotive fuel pump. £100
Stock E39 M5 airboxes modified to fit E30, with K&N RC-5136 cone air filters. £170
Full stainless custom made exhaust, with equal length headers. (Section of floor needs to be modified to fit.) £1100
Mishimoto radiator. £180
Volvo header tank with modified (2 bar) cap. Inc. mounting brackets. £90
Mishimoto fan. £40
6 speed gearbox. £1000
Clutchmasters FX250 semi paddle clutch. £450
Lightweight TTV single mass flywheel. £450
Professionally modified propshaft with new centre bearing. £150
Very rare medium case BMW Motorsport group N 4 plate differential. Stripped, cleaned, and
rebuilt with new bolts and plates. £1250
E36 D2 adjustable coilovers with around 100 miles use. £550
Custom made adjustable top plates for E30 fitment. £50
E36 M3 Evo front hubs and control arms. £350
E30 M3 control arm mounts. £50
E46 CSL 345mm front discs. £200
135i 6 piston front calipers. £475
135i rear calipers. £225
Adjustable rear beam. £100
Whiteline anti roll bars. Front 24mm front, 16mm 3 point adjustable rear. £200
Z3 steering rack with proper splined shaft and correctly modified UJ’s. £250
Fully strengthened front sub frame.
Recaro SRD seats, mounted to E30 sub frames. £500
Custom servo bracket designed to run the servo under the glove box. Comes with
Clio servo. VW Sharan 25mm master cylinder, shortened glove box and brackets. £300
Akmpower
Post Fri May 04, 2018 9:51 am
Pm sent
Akmpower
Post Wed May 09, 2018 5:27 pm
I have sent you a pm regarding parts, don’t know if you have received it?
