E30 fuel tank??
Fitzye30
Hi guys trying to find out are all the e30's petrol tanks the same??
Satan
I think there was a long range tank that added an additional 15ltrs capacity.
mikemike
there are 3 different size tanks , ie 1 for the saloon 1 for the touring and 1 for the convertible as the floor pans are different
clipper
http://www.e30zone.net/e30zonewiki/inde ... #Fuel_Tank
Wiki is your friend!! 2 tank types 55l and 63l.
The 15l long range tank was only available in conjunction with the 55l tank AFAIK, and also I believe it was only an option for S14 or M20 engined cars.
What I know for certain is that it is a real b*gger to fill right up.
Shouldn't be, if all the vent pipes are clear and connected properly.clipper wrote: What I know for certain is that it is a real b*gger to fill right up.
There's a large vent from the RH side of the tank and a smaller one from the LH side. Both go to a spill tank in the RH rear upper wheelarch, with a tube going from there to the top of the filler neck.
