E30 Alpina exhaust manifold heat shield
reggid
Post Sat Dec 16, 2017 9:23 am
does anyone have any pics of the Alpina heat shield they fitted with the 6 branch manifold?
E30 325is with M20B31
pukar
Post Mon Dec 18, 2017 12:28 am
https://www.google.co.uk/search?biw=128 ... 1PvqBJf2_8
they just look like regular ones to me?
reggid
Post Mon Dec 18, 2017 7:42 am
there is an extra piece that looks to clip onto the standard heat shield pg 10 but not sure if this is the only attachment method
http://www.thealpinaregister.com/downlo ... ts/e30.pdf
http://9tro.com/media/features/tuned-ca ... m-the-past
pukar
Post Tue Dec 19, 2017 8:22 pm
oh, right, not seen that before... is it genuine alpina?
reggid
Post Thu Dec 21, 2017 9:23 am
yes, the pdf shows part number but wouldnt know where to get one. i was going to make something similar
pukar
Post Thu Dec 21, 2017 8:07 pm
email alpina with the part number and they'll tell you if it is nla
export@alpina.de
although showing off your alpina six branch is surely more aesthetically pleasing?
reggid
Post Fri Dec 22, 2017 7:31 am
Puts a shitload of heat into the engine bay even with ceramic coating
pukar
Post Fri Dec 22, 2017 1:13 pm
but will the extra metal stop the amount of heat, i can't see how unless it shifts the heat outside of the engine bay? the heat shield are just to stop the HT leads getting too hot i thought...unless i'm wrong :?
those leads all over the heat shield in the pic you posted looks wrong as well... should they not be tidy in a rail? they would probably rest on the manifold if that extra metal was not in place.
might be worth asking alpina the question when you email them. it would certainly be interesting to know what it's real purpose was. could you post up if you find out?
Post Fri Dec 22, 2017 2:01 pm
pukar wrote:but will the extra metal stop the amount of heat, i can't see how unless it shifts the heat outside of the engine bay?
Looks like it'll catch a fair bit of air flow from the radiator/fan, so it probably does remove a fair bit of exhaust heat out the bottom of the engine bay.
Agree about the ignition leads. Tied together like that, there'll be a fair bit of inductive coupling between them, increasing the rise time of the EHT, reducing its peak value, and raising the possibility of a couple of extra plugs firing as well as the one that should be.
BenHar
Post Fri Dec 22, 2017 4:49 pm
Brianmoooore wrote: Agree about the ignition leads. Tied together like that, there'll be a fair bit of inductive coupling between them, increasing the rise time of the EHT, reducing its peak value, and raising the possibility of a couple of extra plugs firing as well as the one that should be.
Why is tying them together any different from having them in the standard ducting?
Ben
reggid
Post Sat Dec 23, 2017 4:14 am
its just a simple radiation heat shield, reflecting the heat downwards. nothing to do with air flow as such or ducting etc. The s50b32 in e36 M3 has one.
my windscreen reservoir water gets hot enough to pressurize from the water heating and a slight leak out the lid. i added a stick on reflective alumized sheet which helped but best to tackle the source as best as possible as everything else in the vicinity is being heated to. dont even ask about the clutch reservoir....
Kedge
Post Tue Jan 02, 2018 12:05 pm
I've considered ceramic coating for my BTB manifold due to the heat it gives off, have you found it to be a waste of money?
Instagram - Kedge85
reggid
Post Wed Jan 03, 2018 12:27 am
ceramic coating works but its not a miracle cure
Post Wed Jan 03, 2018 5:48 pm
And what problems are you suffering from heat then?
these sheilds came about so i'm told because in hot weather and heavy traffic the MD of BMW GB suffered some melted HT leads in his C2 2.7 back in the day. He wasn't amused and big cheeses get results so this is what they came up with
the E34 bi turbos have something very similar but the heat off two turbos is a fair bit greater!!
reggid
Post Thu Jan 04, 2018 12:57 am
i am also trying to reduce inlet air temps on hot days and reducing under bonnet temps as much as possible and reflecting the heat down as oppose to letting it make its way over to the inlet side is one of many things i am doing.
Post Thu Jan 04, 2018 6:03 pm
Are you running a standard air box?
Post Thu Jan 04, 2018 6:31 pm
Cutting the rear 3/4 off the bonnet is a popular mod nowadays winkeye
reggid
Post Sun Jan 07, 2018 5:21 am
Simon13 wrote:Are you running a standard air box?
custom airbox with ITB, needs to be sealed off from the engine bay properly currently sucking through a cone....
IAT were 70C today with A/C running car stationary but it was 46C outside in the shade. coolant temp was between 86-90C
