M3 ECU & chip
BMG
Post Sat Dec 02, 2017 10:30 pm
My Euro M3 should have the later 091 ECU( for late spec Euro 215bhp cars ) , but for some reason has the early 071 ECU with some kinda unknown aftermarket chip fitted, worryingly with numbers which might refer to a 2.5L S14.
So a couple of questions.
1, Is it correct the ECU's are the same, bar the chip.
2, Who can burn the correct 215 chip
3, There are lots of aftermarket chips for sale, mainly in the US, but seem to be intended for the US spec 195 bhp cars, so are they a waste of time in a 215bhp car.
TurtleDesignTech
Post Sun Dec 03, 2017 3:10 pm
I understand Speedtouch is your man. Send him a pm.
BMG
Post Tue Dec 12, 2017 9:29 pm
Bump
BMG
Post Sat Feb 03, 2018 4:41 pm
Still looking for info and a chip
Captain_Birdseye
Post Sun Feb 04, 2018 2:52 pm
Ye, I'm always a bit wary of US chips because I'm sure they're designed with US petrol in mind. There's several companies in the UK witg decent track records (no pun intented). Superchips is one, also, the UK company who were licensed by Hartge to produce/upgrade e30s are still in business but they go under another name, so google will be your research tool there. And also, as already suggested: contact speedtouch because he'll be a fountain of knowledge on the subject.
BMG
Post Sun Feb 04, 2018 10:04 pm
Thanks. I'll send a email to them and see what they say. I did PM Speedtouch, but got no reply.
kundiboy
Post Thu Feb 08, 2018 10:58 pm
Yes the ECUs are the same it’s just the chip that differs between the 195 and 215 models. I don’t have a 215 chip or you would be welcome to it.
1988 Diamond Schwartz E30 M3
BMG
Post Fri Feb 09, 2018 5:11 pm
Thanks. So at least the ECU's are no different, just sourcing a correct 215 chip will effectively give me the 091 ECU.
DHFiS
Post Fri Feb 09, 2018 8:20 pm
If I was you I would have it tested on a dyno to find out what it makes now, if the current set up makes good power then leave it as it is.
BMG
Post Fri Feb 09, 2018 8:49 pm
DHFiS wrote:If I was you I would have it tested on a dyno to find out what it makes now, if the current set up makes good power then leave it as it is.
Not possible at the minute...
Image100_1437 by e30 m3, on Flickr
