Plastic grill in the under dash panel
ChrisHC
- E30Zone Contributor
On the driver's side the under dash panel has a plastic grill inset into it, and plastic clips that would clearly hold a rectangular object up against it on the inside. Just out of curiosity, what is that for?
Cloggy Saint
ChrisHC
No, I have an OBC and it does it's own dinging.
BenHar
In that case someone has fitted the bonger in the wrong place.ChrisHC wrote:No, I have an OBC and it does it's own dinging.
The small grill in that panel is where it should be.
Ben
ChrisHC
All I have is a little peeper between the OBC and the heater temperature control.
If I only have a little peeper while other people have big bongers my life is ruined!
Cloggy Saint
ChrisHC
Right, so I am missing a gong which should operate with the OBC. What should the little peeper do? All mine ever does is peep three times when I turn off the ignition, which is not at all useful and actually slightly irritating.
Sure that's not coming from the radio? I used to have a radio that did that when the ignition is turned off, and yes, it was slightly irritating. It's supposed to be a reminder to remove the radio face and take it with you.ChrisHC wrote: All mine ever does is peep three times when I turn off the ignition, which is not at all useful and actually slightly irritating.
ChrisHC
I suppose it could be, that never occurred to me. I will listen more carefully.Brianmoooore wrote:Sure that's not coming from the radio? I used to have a radio that did that when the ignition is turned off, and yes, it was slightly irritating. It's supposed to be a reminder to remove the radio face and take it with you.ChrisHC wrote: All mine ever does is peep three times when I turn off the ignition, which is not at all useful and actually slightly irritating.
If so, what is the function of the thing between the OBC and the heater control, is it in fact a peeper at all?
BenHar
It's where the temperature sensor would be if the (very rare) climate control system was fitted.
Ben
Ben
Gert_8
- Location: In your back passage faster than a rat up a drainpipe!
The under dash panel actually needs a piece cut out to fix the "bonger". Many people don't do this, and leave the bonger lying inside the panel....?
Kedge
Think it was always old Sony headunits that did that, never knew the reasoning behind it.Brianmoooore wrote:Sure that's not coming from the radio? I used to have a radio that did that when the ignition is turned off, and yes, it was slightly irritating. It's supposed to be a reminder to remove the radio face and take it with you.ChrisHC wrote: All mine ever does is peep three times when I turn off the ignition, which is not at all useful and actually slightly irritating.
BenHar
It's to remind you to take off the removable fascia for security.
Ben
Ben
