tidy 325i on eBay
fazerman
theres a tidy looking or is it? e30 325 auto
on eBay at min for £3k
has anyone seen ad and whats your opinion?
not savvy about these cars and i also need an auto....
cheers
eBayer:263060878130
cheers
eBayer:263060878130
Cloggy Saint
Stefan on probation
You'd need to view it, sunroof model, 4 doors and an auto is less desirable then other cars but for £3k or a bit less when negotiating could be a decent but.
Seller, zero feedback so best to check the car over in person.
fazerman
thanks for replies
i noticed no feedback so have to be wary
hoping was in family or something similar
i.e. cosseted all its life
Stefan on probation
My advice be quick to view it if its the car you are looking for.
M3KUK
I think that has been up for a while without selling. The BBS wheels look like 14's or is it just me?
Stefan on probation
Check the MOT history car was on 53K in 2005.
tha881
fazerman
thanks for replies again..
you say sunroof needs a check?
to make sure working ok?
is it me or are e30s best looking saloon ever?
auto and four doors ok with me
cheers everyone
cheers everyone
Stefan on probation
Drainage holes get blocked so the roof rusts. Its just you.
No! Not working is easily cured - just needs a good service,fazerman wrote: you say sunroof needs a check?
Rust is what you're looking for, unless the roof has been sealed shut, which signifies most of below.
Rust starts on the four brackets that hold the sunroof panel to the mechanism. It would be a rare E30 that has no rust at all here, but the rust spreads, and eventually appears on the top of the panel as rust bubbles. If it's reached this stage, the panel is scrap.
The rust also affects the sunroof 'cage' that carries the whole mechanism. If this is rusted through, rain water will leak into the cabin, but worse is if there are rust bubbles in the roof around the sunroof. These are not chips in the paint, whatever the vendor says, and require a complete roof replacement (=very expensive) to cure.
fazerman
Brianmoooore wrote:No! Not working is easily cured - just needs a good service,fazerman wrote: you say sunroof needs a check?
blimey !!!
i will be very thorough now thank you
so assuming its not that bad is it easy to unblock said holes
that drain from sunroof?
cheers
Stefan on probation
If the holes are blocked the roof will most probably be buggered.
tom325ise
I've got exactly the same car as this one - Mine came with the 14 inch alloys and the spec sheet had the code
281 Lm-rad 6 1/2 X 14 Lm-rad 6 1/2 X 14
Spec sheet for this one is below and shows option 288 for the wheels so they may have been added at the factory
Vehicle Registration Number H930EFC
Model 325I SE AUTO
VIN (Chassis)WBAAD22050AF65999
First Registration Date 01/09/1990
Vehicle Identification Number WBAAD22050AF65999
Type AD22
Model 325i - EUR
Development Code E30
Chassis LIM
Steering RL
Doors 4
Engine M20
Displacement 2.50
Power 0
Drivetrain HECK
Transmission AUT
Color Diamantschwarz Metallic - 181
Upholstery Silber Stoff - 0377
Production Plant MUNICH
Production Date 1990-06-26
Options
200 Katalysator - Entfall Katalysator - Entfall
215 Power Steering,depending On Engine Speed Servolenkung, Drehzahlabhaengig
219 Sport Leather Steering Wheel Sport-lederlenkrad
288 Lt/aly Wheels Leichtmetallraeder
339 Satin Chrome Shadow Line
350 Waermeschutzglas Gruen, Rundum Waermeschutzglas Gruen, Rundum
401 Sliding/vent Roof, Electric Schiebe-hebedach, Elektrisch
411 Window Lifts, Electric Fensterheber,elektrisch Vorn/hinten
428 Warning Triangle Warndreieck
497 Centre Armrest In Rear Mittelarmlehne Im Fond
498 Headrests In Rear, Mechanic. Adjustable Kopfstuetzen Im Fond
500 Headlight Washer Sys/intensive Cleaning Scheinw.waschanl./intensivreinigung
551 On-board Computer Ii W Remote Control Bordcomputer Ii Mit Fernbedienung
723 Edition Zg Edition Zg
750 Basisumfang Fuer Edition Basisumfang Fuer Edition
812 England Version England/irland Ausfuehrung
850 Add Fuel Tank Filling For Export Zusaetzl. Tankfuellung Export
925 Shipping Protection Package Versandschutzpaket
Model 325I SE AUTO
Type AD22
Model 325i - EUR
Chassis LIM
Steering RL
Doors 4
Engine M20
Displacement 2.50
Power 0
Drivetrain HECK
Transmission AUT
Options
