Restore/renew plan for my facelift cab
georgee
Post Mon Jun 12, 2017 3:50 pm
Hello
I have owned my cab for over 10 year and unfortunately I have let it fall into a bit of state...well NO MORE!!!(Shouting like I was in an action move)
my goal is to make a diamond schwarz motorsports cab( if they made one I would have brought it)
So the plan
Engine
Hasn't been started in over 5 years. The head gasket went which I had fixed but it continued to drop oil everywhere so I plan to pull the engine and transmission during the August bank Holiday (plenty of time to do some research as I have never done this before, I am very new to wrenching)
Head rebuild or new head(amc)
replace all electric components with OE (bosch,Bremi,Karlyn,etc) or BMW :cry:
Replace all belts with contitech
Replace all pulleys tensioner with INA
Replace all cooling with Behr,Wahale etc.
Replace hoses with bmw :cry:
Gaskets will be victor or elring....the markup from BMW is f'ing ridiculous....they dont'make the f'ing things!
Suspension
Everything Lemforder (inc e46 top hats and 3 mm pads)except
M-tech springs
Sachs Boge shocks
corteco engine mounts(got to check dealer prices)
skf front and rear bearings
Drivetrain
everything out for a full inspect, powder coating and refil
gkn cv kits or new driveshaft depending on state
3.64-391 lsd (still haven't decide,more research required)
Brakes
calipers powder coated and rebuild kits
disk and pads of course(not pagid...f'ing squealers)
I don't remember having any issues with the brakes but hydroponics may have causes issues with the master/slave d
Clutch
I will wait and see what sachs and skf parts I need.
So is there anything I am missing?? (apart from the massive hole in my wallet)
Post Mon Jun 12, 2017 7:32 pm
Have the injectors cleaned, new fuel filter and possibly pump.
All new brake hoses and check the metal brake and fuel pipes.
