"You have been blocked from entering this site.
You are using a possible Harvester on this site.
All of the following information has been gathered to assist the webmaster should this need to be report to local or federal officers.
User Agent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1; .NET CLR 1.1.4322; InfoPath.1)
Remote Address: 86.137.168.239
Client IP: none
Forwarded For: none
Date Blocked: 2006-01-13 21:26:27
Block expires: Permanent"
what do i need to do to get me unblocked
cheers
Z
Currently blocked, need to be re-instated please
kam-325i
Are you on AOL ?
It looks like BT are playing up again(BTCentralPlus.com)
xedman
im using BTYAHOO
im currently accessing from work, which is BT and thats fine
Z
Z
kam-325i
Its nothing this end that cause's the problem, it is to do with the way BT are routing your IP traffic. There was a load the other day that had the same problem, it cleared up after a few hours.
xedman
i thought it might clear up on its own but this has been ongoing now for a month
Z
Z
kam-325i
A Month !!!!! Jesus.........
The reason the site is blocking you is beacuse of the "Harvester" bit. Harvesters are programs/IP's/Bots that "Harvest" email address's from forums for the purpose of spam.
Ill have a look on the black list's to see if your IP has been used for any spamming.
kam-325i
IP Address is listed on two blacklists
Look for the RED ones.
http://www.dnsstuff.com/tools/ip4r.ch?ip=86.137.168.239+
xedman
Cheers Geez,
im very meticulous when it comes to viruses/spyware, let us know what you find
Z
Z
kam-325i
It wont be because of something you have done, it will be because of who ever had your IP address before, has been doing naughty things, so some put the IP on a list, then it cause's problems for the next person who has the same IP.
Answer in above post
