anyone use camber plates on non coilover set up ?
puregttipower
Post Wed May 10, 2017 9:45 am
hi guys is it possible to use camber plates on lowering shocks and springs on e30 cabby? i read on one ebay advert guy put you need coilovers?
any help will be great
thanks
steve_k
Post Wed May 10, 2017 7:32 pm
i've got a set of eibach/spc camber adjustable top mounts on my sport with a shock/spring set up, never had any problems in the 10yr's they've been on the car.
puregttipower
Post Wed May 10, 2017 8:16 pm
thanks for info will something like below be ok to use?
http://www.ebay.co.uk/itm/Camber-Plates ... 2649538356
ross_jsy
Post Wed May 10, 2017 8:18 pm
Why do you want to adjust the camber/castor on a cab :?
steve_k
Post Wed May 10, 2017 8:21 pm
they look like they would do the job,
at that price range just be careful with the bearings as they might need greasing once a year at best or replacing at worst.
these are the one's i've got
http://www.ca-automotive.co.uk/variants ... 3NA==.html
but as you can see not cheap lol,
the ones you've posted should be fine though, just be aware that if you go for full neg camber the top hat on the shock will rub on the inside of the strut tower.
puregttipower
Post Wed May 10, 2017 8:45 pm
thanks for info steve, ... rossy im going 9.5 on the front thats why :)
