Can anyone help me please ?
I've been searching about but can't seem to find anywhere I can hold of the brake line adapter needed to fit RX7 calipers to the standard E30 brake line.
the adapter needed is :
M10 male inverted flare to M10 female bubble flare
Does anybody know where I can get hold of them ?
James
Help ! - Brake line adapter
E30spud
Would it not be simpler just to get another brake pipe made up with the correct flares?
JBentley95
Yeh ive done alot of that and haven't come up with anything in the UK. I think making up a brake pipe will be the only option.
Carl911rugby
Try these
www.thinkauto.com
They made me a vanos line for an an m52 engine with s50 oil filter housing. Fast delivery quality product and very good value!!
Carl
www.thinkauto.com
Carl
JBentley95
Thanks Carl I'll check it out.
rix313
There are a few places that can make up lines for you. Think Auto are great. Also try the likes of Merlin Motorsport at Castle Combe. Earls Performance at Silverstone to name a couple.
JBentley95
I think it may no longer be a problem because as I noticed that the Hel brake lines I have seem to use a universal flare on them and are the same thread. I checked the mating between the brake line and calliper by putting black marker around the concave part of the flare and winding it into the calliper. All of the black marker rubbed off the flare so it must be sealing...
