where to get drive shaft boot - kits
Tedswagon
Hi all,
I need to replace both inner and outer boots on both drive shafts and I would like advise where best to get the kits from. Can you recommend anywhere?
There are only inner kits on car parts 4 less. http://www.carparts4less.co.uk/cp4l/c/B ... 056&000445
Many thanks in advance.
brutus
for new - try europarts
MANY e30 PARTS FOR SALE.
( all models available )
318i baur 1986 auto.
Tedswagon
Cheers Carl, Car parts 4 less is Euro car parts, just better value. Euro don't have it either.
Kedge
I believe the E36 uses the same ones, and ECP does sell those.
Tedswagon
Oh thanks for that Kedge. I should have guessed. I'll search for e36 compact ones. Cheers.
If you can only find what you want on ECP, and not on CP4L, copy the ECP part number into CP4L and it should work, giving a lower price than that on ECP.
Tedswagon
Cheers Brian
KW355
Which comes up as 32.99GBP, including a 16% 'saving' apparently.KW355 wrote:The ecp part numbers are on my thread;
http://www.e30zone.net/modules.php?name ... c&start=50
Same part code entered into CP4L gives 22.20GBP less usually at least 10%, depending on what discount code you can use at checkout.
Tedswagon
Many thanks - you should always check carparts4less as well as euro - they are part of the euro group so same things on their site. Always a bit cheaper!!KW355 wrote:The ecp part numbers are on my thread;
Your build looks fantastic by the way.
Sanchez
Plenty on eBay Ronan.
Sanchez
Spent a few happy hours a month ago replacing the almost new CV joint 'ebay' boots, along with the almost new track rod ends (split boots only), on a car I bought my lad, cursing the cheapskate previous owner the whole time.Sanchez wrote:Plenty on eBay Ronan.
Buy quality parts, such as GKN from CP4L, and do the job once only.
Sanchez
Meant for the carparts4less eBay page.Brianmoooore wrote:Spent a few happy hours a month ago replacing the almost new CV joint 'ebay' boots, along with the almost new track rod ends (split boots only), on a car I bought my lad, cursing the cheapskate previous owner the whole time.Sanchez wrote:Plenty on eBay Ronan.
http://pages.ebay.com/link/?nav=item.vi ... 1240183083
Tedswagon
Thanks Peter and Brian. I'll check those out this evening after work.
R
R
