Hi just want to confirm which gearbox oil to use on my switchable auto 325i?
4hp22 i beleive.. also how many litres are needed is system is completely drained?
Thanks saj
Which gearbox oil to use?
sajad09
ATF Dexron 3 which you can get from pretty much anywhere, buy two 5 litre tubs and you will have enough to renew the PAS fluid also
sajad09
Cheers mate good idea that.
