m20 eta 2.7 elaborate ?
Post Fri Nov 04, 2016 12:22 pm
as some of you already know i've purchased a breaker with an eta 2.7 using a 320i head .
can someone explain why they built/build them this way from a 325ie 525ie ?
i'm not used to these 12v donks so tia Mick .
Post Fri Nov 04, 2016 7:56 pm
what do you exactly want to know?
Post Fri Nov 04, 2016 8:09 pm
Simon13 wrote:what do you exactly want to know?
found this mate , explains it all 8)
www.e30zone.net/e30zonewiki/index.php/Building_a_2.7
thanks anyhoo :)
MattTheHat325
Post Fri Nov 04, 2016 8:24 pm
It's a straightforward option when building a stroker as it already has the increased capacity so you don't have to bother swapping cranks and rods etc. It's an easy way but not the most efficient in the long run as you are restricted to the 731 head (320). The best head is the 885 from the 325i as it has bigger valves and ports and generally flows better, but it needs to be used in conjunction with the 325 pistons, which would obviously involve a crank and rod change in order to gain the extra capacity AND utilise the better flowing head.
Its almost like putting a 731 head on an eta short block is the m20 equilavent to an m50 manifold on an m52, whereas building one from the crank up and using an 885 is more on par with knocking up an m52b30.
Post Fri Nov 04, 2016 10:52 pm
The project in question is to be sold when i'm happy it's good to go , leaving options open for the new owner and having the relevant knowledge to hand is awesome :D
http://www.e30zone.net/modules.php?name ... c&t=269261
if i do it all i'll get attached , i'm already doing it slowly to keep me hand in .
Post Fri Nov 04, 2016 10:54 pm
photo buckets down till 2 am :roll:
