a proper 'barn find'....
when and how i found it...
delivered today.....
probably not byron, but nothing that wont be reversible...maggspower wrote:Just going to put it all back to standard, is it Glenn?![]()
Well theres a shockglenn wrote:probably not byron, but nothing that wont be reversible...maggspower wrote:Just going to put it all back to standard, is it Glenn?![]()
And how did you discover this gem!Cloggy Saint wrote:Ok, I'll be the first to ask, how much?
And how much of it is missing?Gert_8 wrote:And how did you discover this gem!Cloggy Saint wrote:Ok, I'll be the first to ask, how much?
brettski wrote:You jammy bugger Glenn how did you find this?
i was 'reading between the lines' of something someone posted on another forum...Gert_8 wrote:And how did you discover this gem!
yep, 2.3Speedtouch wrote: I take it an engine is fitted, judging by the ride height; 2.3 or 2.5-litre?
this 'barn' had about 50 cars in it. there was another e30 m3, e30 sport, a couple of 'normal' e30's, several 911's, and some vag stuff....Cypriotgeeza wrote:Why can I never find these barns with cars stashed in them?!
its 99.9% completeBrianmoooore wrote:And how much of it is missing?
a lady never tells her age !Cloggy Saint wrote:Ok, I'll be the first to ask, how much?
he looking to sell any of the rest of it?glenn wrote:this 'barn' had about 50 cars in it. there was another e30 m3, e30 sport, a couple of 'normal' e30's, several 911's, and some vag stuff....Cypriotgeeza wrote:Why can I never find these barns with cars stashed in them?!
Subscribed !!maxfield wrote:S63?
s63...maybe.....M5London wrote:Subscribed !!maxfield wrote:S63?
subscribedmaggspower wrote:Well theres a shockglenn wrote:probably not byron, but nothing that wont be reversible...maggspower wrote:Just going to put it all back to standard, is it Glenn?![]()
Look forward to seeing it develop.
yes si,Simon13 wrote:Is S63 the M5's V8 twin turbo jobbie?!
i've been a passenger in one too...and i thought the same as you !!Simon13 wrote:It will destroy an e30! i've been lucky enough to drive an F10 M5 and the power is proper mental
thanksSimon13 wrote:Knowing you this sounds about right boyo!
bss325i wrote:will be interesting to see how you get on with bulkhead clearance as the turbos and in the V and the down pipes run down the back of the heads and around the bell housing.
i knew about the exhaust routing,Simon13 wrote:Sounds like it needs a hartge H36 bulkhead!
