6-pot ecu's
is it possible to use a motronic 1.3 320i ecu with a 325i super chip and use this in a 325i ?
+ a yard full of scrap turds
Short answer - yes.
thought soBrianmoooore wrote:Short answer - yes.
E30rocknrollstar
Is they any downsides to this set up, from using a 325 ecu
tha881
Only downside is that it might confuse some future mechanic when he finds the wrong ECU fitted.
All later six-pot Motronic 1.3 ECUs (172/173/179/380/381) are all essentially the same, aside from the program on the EPROM chip and the label.
Only significant difference is the later 380/381 has extra diodes for the idle control circuit (which are prone to blowing).
