Hi I got a 325i 1988 switchable auto and I need to top up the gearbox oil, I've spoken to BMW but they can't advise me which oil to use. Any ideas?
Also need to know what's the best diff oil too
Which Gear box oil to use
Just any dexron 2 or 3 is fine for an e30 auto box. Do you have limited slip differential or open?
darkchild
Dexron II was the OE oil which has largely been replaced by Dexron III. Worth doing the filter too - they're cheap enough.
JagsK1981
I have a limited slip diff on it
JagsK1981
Thanks for the advice guys
maxfield
Limited slip diffs uses Castrol syntrax 75-140w - if it's a medium case diff then you want 1.7l of oil:
