help on what lsd ratio m50?
G4V11N
Post Mon Sep 05, 2016 1:45 am
Hi
GoING to be using a getrag 260 with a M50b25 non vanos in a touring.. 16" wheels and unsure what's beat ratio too use?
I have a 3.91 and a 3.15 lsd at hand bur unsure if these are what's best too use.
Any help?
ross_jsy
Post Mon Sep 05, 2016 8:05 am
3.91 will work. You will need lower geared diff as 5th is .81:1. If you were using a ZF unit they have a 1:1 5th so you need a higher diff (say a 3.15).
