Hi all,
I'm building a M50 turbo looking to achieve 500-550bph. Hx35/40 turbo
Now, I want good drive ability and be able to reach top end speeds of around the 160mph mark.
The gearbox is a E34 S5D 250G and I was thinking of mating it to a med case 2.65 or 2.93 LSD. 16" wheels max, possibly using 205/50 tyres.(rears)
I just want peoples thoughts and opinions, especially from those who have/had boosted cars.
Regards
Kam
Diff question
4G63TEVO
S38B38
I think this gearing ,, 2.65/2.93will suit the G250 box very well,,,,, as the 5th gear is 1:1
Sveinbjörn Hrafnsson
E30 CABRIO M70B50 V12 5lug
ALPINA B10 BITURBO 346@507
550 V12 JML Motorsport
ross_jsy
I am using a 2.65. Theoretical top end of 203mph if it could rev out in 5th
Should build boost well as the engine will be under load. Plus the lower ratio diffs are stronger.
I'm selling an unused plug and play VEMS standalone for an m50, along with a rapidspoolindustries manifold. Let me know if you are interested
4G63TEVO
Thanks pal but I've already got VEMS and a manifold.
What's your rev limit. Assuming you're running M50
ross_jsy
I've decided to go with an s54 now. I was going to set the m50 to 7k but I've heard they don't like sustained high revs
