Who's lowered 60mm? Pics please (if possible)
e30-unit-soldier
Post Fri Aug 26, 2016 4:31 pm
Hi guys I want to lower my 325i cab currently sits lower at the rear and higher at the front... I really don't like the look.
I want to lower it but just debating on different drops.
40mm
60/40
60mm
:mad:
Any advice or recommendations?
jmc330i
Post Fri Aug 26, 2016 4:37 pm
Is it a facelift car?
James
'91 325i Sport
'93 318i touring 16v
Cloggy Saint
Post Fri Aug 26, 2016 4:39 pm
I've had 60/40 and hated it. It looked council and was not a comfortable ride. If you want to level things up I'd go for 30/10 but I'm not sure such a kit exists so maybe just lower the front so it matches the height of the rear.
e30-unit-soldier
Post Fri Aug 26, 2016 6:25 pm
jmc330i wrote:Is it a facelift car?
D reg chromie
Post Fri Aug 26, 2016 6:48 pm
Lowering an E30 by 60mm, simply by shortening springs, moves the suspension out of its designed operating parameters, and, without going into technical details, it does just not work.
e30-unit-soldier
Post Fri Aug 26, 2016 6:50 pm
Brianmoooore wrote:Lowering an E30 by 60mm, simply by shortening springs, moves the suspension out of its designed operating parameters, and, without going into technical details, it does just not work.
What about a eBay coilovers kit would that still be the same?
Post Fri Aug 26, 2016 6:51 pm
Even worse! The only way to lower a car by large amounts is to effectively lower the body on the chassis.
e30-unit-soldier
Post Fri Aug 26, 2016 8:47 pm
The car recently had some b4 shocks fitted just before I bought it so I was just thinking of fitting 60mm springs.....
Post Fri Aug 26, 2016 8:58 pm
Good quality 35mm - 40mm springs (= Eibech or H&R) and the B4s, will work perfectly, as long as all bushes are good.
andysheep
Post Fri Aug 26, 2016 10:26 pm
Im lowered about that pics in bmw chat ,my cabbie build,but i wouldnt do it again :roll: i did it to my tin top and its a pain in the arse,i ended up changing it,it looks good but doesnt take advantage of the great bmw handling,so if you want low go dub :eek: andy
