Hi,
The rh headlight wash on my tech 2 325i sport has developed a healthy leak behind the headlight unit. Can anyone shed some light on potential fail / fix. Not 100% sure on the look. What's involved in removing the entire mechanism.
K
Headlight wash leaking
Little in line valve has failed. Readily available from BMW.
krog
Thanks Brian, had a look on realoem for the part no. Could you please point me in the right direction
krog
Thanks Brian, that is way better than realoem.
