S50 problems again
Siggo
Car still cutting out again when driving. Have replaced crank scencer. Maf cleaned the earth wires replaced 6 rubber trumpets.fuel pump ok car even worse than before any idears
bigbird76
ECU Dry solder joints?
Siggo
Will put it on the check list thanks
maggspower
- Turbo Farmer Tractor Driver
have you had it plugged in, and the codes read
Contact: theengineshedonline@gmail.com
Siggo
Yep that's why replaced air mass metre and crank scencer
Siggo
It also idles now at 900 revs. My research still saying crank case sensor
maxfield
What make crank sensor did you use?
spook
- League two here we come !!!
crank case sensor 150 from the dealers mate
spook
Is the crank sensor showing bad on your code reader?
Siggo
No. Got time of work soon . Taking inlet manifold off check idle valve. pipe work for splits see if that helps
Siggo
Replacing throttle position senser see if that is the problem
Siggo
Replaced throttle sencor . Cars running great so far
