Brake servo
BMG
Post Sat Jun 04, 2016 1:23 am
The servo of my M3 is rusty in places and the master cylinder needs new seals and a clean.
I removed the concertina plastic boot after having looked at the ETK drawing and expected to see some kinda air filter underneath , but nothing. Peering down where the push rod exits, you can see a foam like substance that seems disintegrated.
The back of the servo has a metal sealing cap covering it , but which doesn't seem to show up as any part in the ETK.
So is the foam like substance the air filter that is under this cap ? I was reluctant to try and remove the cap as it doesn't seem available.
Cloggy Saint
Post Sat Jun 04, 2016 9:20 am
The gasket between the servo and bulkhead is made of foam so it's probably the remains of that.
BMG
Post Sat Jun 04, 2016 10:28 am
Can't be. This is under the rubber boot and right down into the servo and a different colour material to the gasket I removed.
