Warning to all E30 owners
TwoTees
Post Fri May 27, 2016 2:38 pm
Hi all,
I need to share this information with as many E30 owners as possible so this doesn't happen to anyone else.
The short version.
I recently replaced some suspension parts including the tie rods on my sons E30 and they broke causing the car to loose control, hit a bank and roll.
Please take note of the seller of these kits and don't buy one. If you know of any one who has recently done any front suspension work to thier E30 contact them and ask where they got thier parts and show them this post. If you frequent other E30 forums please post up a link there back to here.
http://www.ebay.com.au/itm/311437146151 ... EBIDX%3AIT
I did look at the sellers feed back but I never did notice this from someone who bought the same kit. We are not the first.
The detailed version.
Firstly, I don't want this post to be taken as some sort of excuse for Luke. He certainly played his part, mainly the speed that he was doing. It is not ok for him to drive like he was, especially when he had a friend in the car. He had a free period from school and decided to go for a spirited drive on a back road before heading back to class with his mate. Also, in part it is for me as I feel as if I hold some of the blame and at the least, want it known that it was not driver error but a mechanical failure and feel i need to document exactly what happened. It should also be known that Luke has had advanced driver training and competes in Hill climbs at the local track. His driving ability is very much above average and he is familiar with correcting over steer.
Anyway, I purchased and installed one of these front suspension kits for him. The car was then taken to a suspension specialist for a wheel alignment.
This Tuesday (4 weeks later) I received a phone call from him during the day and he said.
"I have rolled my car. I wasn't going excessively fast. I tried to correct it but I couldn't do anything with it."
I got to the scene and found this.
How the hell he and his friend were not badly hurt is beyond me. I spent some hours there waiting for police and tow trucks etc and I kept looking at the marks on the road and I could not for the life of me work out how he went off where he did. The Police officers explanation was that he lost it half way through the corner, over corrected, over corrected again coming out of the corner out of control and into the bank on the right. There were no fish tail skid marks anywhere through the corner only the straight marks heading straight at the bank. Luke says he did not fish tail through the corner. I trust that if he stuffed up he would simply say so.
Once the car was at home I was looking over it and it occurred to me that the front left tie rod was still perfectly straight but the connection to the inner rod (rack end) had come apart. I need to stress at this point for those who may not know, that this connection in the tie rod is supposed to be a permanent connection, never to be taken apart. It is crimped onto a threaded rack end rod.
The front left wheel took the first impact into the bank, was torn down and under the car. The sway bar brackets were ripped down, the control arm bent down and torn off yet the rack with the rack end looked fine and the tie rod hardly had a scratch.
I looked to the right front suspension and the tie rod end was attached to the steering arm but the tie rod was snapped off and no where to be found. The rack end was neatly sitting in the end of the rack. The rack ends, rack mounts and the rack itself has absolutely no signs of stress. The front right wheel is still located in its correct place yet no tie rod to be seen.
Here's what I think happened. He came through the corner and as he straighten the right front tie rod connection gave way. This caused right wheel to turn hard right and cause the car to head right across the road possibly pushing the rear out going by the marks on the road. At this point the extra load on the left tie rod caused it to let go also. The car and front left wheel slid sideways into the bank tearing the wheel down under the car and the car rolled over. At this point the right wheel is hard back in the mud guard and as the car rolls over, the tie rod if flicked outward. As the car came down onto its wheels again the right tie rod was speared into the hard, decomposed granite and then was torn off as the car kept moving. The bend and break point in the tie rod end fits right onto the rim edge.
I believe this because I went back to the site and found the right tie rod embedded into the ground about 4 meters from the initial point of impact of the left wheel into bank. At this point the right front has had no impact, yet the tie rod is in a position to spear into the ground. It must have been broken! The car then continued to roll several more times coming to a rest.
Image Image
I also pulled apart one the original tie rods that were removed. It required the pressed part to be heated glowing red, an 18" shifting spanner and set of vice grips in a large vice to separate them. You can see in the photos the original has quite deep impressions from the thread and when I run a screw driver over them you can hear it clicking.The cheap replacement has only very slight marks that can not even be felt.
I am convinced that both tie rods broke causing the crash. Certainly there is blame on Luke because of the the speed he was doing. The speed limit there is 100km/h and he says he was doing around 120km/h. His mate also kept saying to me during the afternoon on the side of the road. "We weren't going that fast" My Landcruiser would go around that corner at that speed, however, if he was doing the speed limit, perhaps it would not have been so bad and maybe just one roll over.
I have contacted the seller (I am fairly confident he speaks English) and told him what I believe, yet he is still selling these sets. I know this because I got my mechanic to purchase another set from him 36 hours after I sent him an email. I may get them tested by someone when they arrive. Not sure exactly yet but I will update this when I get them and do something. Any suggestion welcome.
My wife has German relatives and we are in the process of trying to find out who in Germany we can contact to get this seller to withdraw these from sale. Its a public holiday there at the moment so will need to wait till Monday.
My son and his mate could have been killed. There is one less E30 in the world, this guy is still selling this crap and I am really pissed off. If there is anyone here that is located in Germany, please, can you offer any help? Any government agency who regulates motor vehicle standard or the like so we can report this guy and get him to stop selling these sets. (or at least the tie rods)
I will get my mechanic to leave some more appropriate feedback on EBay once we get the new set and I might try EBay for recourse, but from past experience they probably wont care.
Thanks.
ross_jsy
Post Fri May 27, 2016 2:49 pm
Shit the bed, that is bad. Pleased to hear your son and friend walked away.
If they are being sold in Germany, I imagine the seller could be in hot water. From what I remember parts have to be TUV certified. Assuming those haven't been, I imagine he is breaking the law
viz007
Post Fri May 27, 2016 6:11 pm
Gosh glad everyone was ok especially in a car without modern safety features
1990 320i convertible viewtopic.php?f=25&t=266514
hennared323i
Post Sat May 28, 2016 6:41 am
viz007 wrote:Gosh glad everyone was ok especially in a car without modern safety features
Wow! People survive crashes in old car shock - get a life you knob.
To be the OP, get that seller reported to the TUV asap. The sooner that crap is off the market the better. Glad only pride was injured.
aimlessrock
Post Sat May 28, 2016 7:14 am
Dear god, this is why I'm so anal about only buying oem/top quality parts....pleased your ok op.
E30 320i Convertible (1989)
190 Mercedes (1988)
Post Sat May 28, 2016 7:42 am
Glad to here your son and his mate are OK after that. Car indeed does look a mess.
This truly is a case of you get what you pay for. PLEASE don't take the following the wrong way as it's intended to bolster the above comment about being anal about OEM parts. I am in not way stating that you should expect a cheap part to break and accidents to happen.
$124 aus dollars (about £62 quid at this mornings exchange rate) for 2 lower arms, 3 drop links, 2 complete steering arms and a pair of wishbone bushes, makes alarm bells ring in my camp.
To put it into perspective, a single OEM Lemforder lower arm is £74 quid on its own at ECP. Thats AU $150.
Even taking the additional AU $140 (£70) shipping into account, the total paid does not even come to a pair of OEM arms.
Many have bought the cheapo drop links that are on the market, only for them to fall to bits in under a year.
Again, so glad everyone is ok and I hope you go someway to getting those shite parts removed from the market all together! It's good you've also highlighted that "cheapness is often a weakness"! Which is exactly what forums like this should be used for.
The seller is still currently advertising exactly the same set up:
http://www.ebay.co.uk/itm/Control-Arm-R ... Sw6EhURhK5
And there's another set up (again from Germany) that looks very similar, that is only £14 more expensive. BUT with free P&P!!!!!! :eek:
Kedge
Post Sat May 28, 2016 8:35 am
Glad to hear that your son and friend got out of that OK :eek: .
What's even scarier is, how many more cars out there are sub standard parts like this fitted to, not just E30s? Doesn't just put the cars occupants at risk, it's all other road users and pedestrians that could be in the vicinity of such an accident.
Instagram - Kedge85
Post Sat May 28, 2016 9:17 am
This inferior chinese shite should have been banned years ago
ross_jsy
Post Sat May 28, 2016 9:31 am
Bit of an overreaction :?
TwoTees
Post Sat May 28, 2016 10:18 am
B7 wrote:Glad to here your son and his mate are OK after that. Car indeed does look a mess.
I do agree with you and I am in fact somewhat embarrassed and devastated for my mistake. I actually could have got a very similar set sold here for a even less. They looked poor quality in the photos and the sellers name was "China Auto Parts". I ended up going with the more expensive set from Germany thinking I was getting a better product. I had heard somewhere before that Germany has better regulation on parts. Here in Australia anyone can flog any crap they like. Clearly, the same applies in Germany.
In the listing they are quoted as having a brand name. Auto-Universal GmbH.
Looking back now and doing a search for this "Brand" it is in fact a workshop. And the proprietors name is Olaf Lange. His Ebay user name is carparts Lange.
http://autouniversalgmbh.de/
This "brand" is also listed on one of those Chinese trade sourcing sites
http://carpartslange.en.ec21.com/company_info.html.
So yes! Anyone thinking of buying cheaper parts, please learn from my lesson. Tail light and badges maybe but critical parts? No!
TwoTees
Post Sat May 28, 2016 10:20 am
Kedge wrote:Glad to hear that your son and friend got out of that OK :eek: .
Yes. From now on I will be wide eyed every time I see an E30 coming at me in traffic.
Post Sat May 28, 2016 5:28 pm
Indeed! There was NO need for that remark as E30's are not safe cars compared to modern cars and even if they were it still doesn't warrant your reaction!
hennared323i
Post Sun May 29, 2016 7:41 am
Ooh!
I'm being chastised by a couple of gaol birds.
I retract the knob comment.
I'm oot
darkchild
Post Sun May 29, 2016 7:47 am
Fair enough that E30s don't have safety features like modern cars but I often think their excellent visibility (skinny A-Pillars etc.) mean you're less likely to get into trouble in the first place.
TwoTees
Post Sun May 29, 2016 10:37 am
darkchild wrote:Fair enough that E30s don't have safety features like modern cars but I often think their excellent visibility (skinny A-Pillars etc.) mean you're less likely to get into trouble in the first place.
Even if it had air bags they would only help for the first roll or two. Then they'd go flat and you have nothing for the remainder of the rolls in this case.
I suppose the car didn't come to a sudden stop. They were violently bashed around for a while until it came to a stop over the course of 30 or so meters. Luke also had his track seat in at the time and I think that would have helped a bit.
When the Fire and Rescue guys turned up they were impressed with the way the car help up tho. I don't know exactly what they have seen before but one did comment "Lucky it was a BMW"
Hitting a tree or another car and suddenly stopping without air bags would be very different I think.
TurtleBoss
Post Sun May 29, 2016 3:47 pm
I feel as if a modern car wouldn't have much more of an advantage compared to an old e30 when it comes to protecting the passengers in a crash scenario like this. The passengers didn't really experience a great amount of deceleration, rather they just got thrown around until the car eventually came to a stop. A lot of the safety ratings in modern cars come from greatly improved crumple zones, whereas in this instance, its the cabin and roof rigidity that is responsible for the safety of the passengers.
dave525
Post Sat Jun 04, 2016 9:22 am
A modern car would have much better roll protection, just look how thick the pillars are.
I wouldn't fancy rolling my e30 cab and drive accordingly especially on wet corners and islands!
driftmaster808
Post Thu Jun 23, 2016 9:02 pm
some of those chinese factories have a lot to fu@@ing answer for :(
i feel sick just looking at photo - glad your son is ok
bmw9818
Post Fri Jun 24, 2016 11:01 pm
wow, gutted for you!! I hate fitting shit parts to any car, let alone the e30,
