Doesn't wanna start
BROOMY
- busy saving Clifford
Iv got this BMW 318IS and it doesn't seem to wann start.
Iv got a working half charged battery that will happily start the car. The cars had no petrol for around 6 month, ran fine previously, I put 10 pound of petrol in it left it in there for about 2 weeks, never needed the car so was not used.
Now comes the weird part. I noticed soon as I tried to start it I didn't hear the fuel pump click before I tried to start, but I tried to start for 4 or 5 times. The problem is the plugs aren't wet.
Slightly damp but not wet. I carried onto a spark check with a fine spark found.
I carried on for about 10-15 times n plugged check, nothing just a slight bit damp but that was probably from before.
Now I'm gonna let the plugs and bores (cylinders) air so I can see what's going on.
From a mechanical point what should I check now or do to start?
Cypriotgeeza
So no noise from the fuel pump..BROOMY wrote:Iv got this BMW 318IS and it doesn't seem to wann start.
Spark plugs dry..
thinking maybe the fuel pump?
I would take off a fuel pipe at the fuel rail, put it in a bottle or container then get someone to crank it over to see if its pumping fuel.. if it is then start looking elsewhere
Check my M30 build threads:
Carmo13
This ^^^Cypriotgeeza wrote:So no noise from the fuel pump..BROOMY wrote:Iv got this BMW 318IS and it doesn't seem to wann start.
Spark plugs dry..
BROOMY
I don't think or know if it's the fuel pump.
I THINK I used to hear a click not sure just thought I remembered it before I started it.
Can someone tell me if there "IS" does as I say or not?
If I have to do this not that I really want to, Is there an easier way to test this?
Presuming I have to remove the manifold to access the fuel rail piping. If not this what should I try ?
Does anything else tell it when to squirt on time that I need to check?
I'm trying to tool myself up so when I do hit it, I get it started and done.
Thank you
Thank you
BROOMY
Guess it's a manifold off time to get to the fuel rail hoses.
Take off the inspection hatch under the rear seat. Pump makes enough noise to be able to tell if it's working.
BROOMY
Does the car need to be cranking or not?
andysheep
Should make a noise the moment you turn the key
good luck
BROOMY
Am I right in thinking you just turn it over, to prime it as its not like a diesel with no pump to prime?
on the passenger side of the inner front wing below the brake servo is silver fuel filter with a pipe coming out of the top , remove pipe and crank engine over , fuel should come out of the filter .
+ a yard full of scrap turds
BROOMY
I tried it today all seems well but now I'm questioning did I remember which way the fuel hoses went when I put it back together.
There's a straight silver one n a angled black one.
Black one comes from top of fuel filter and leads to the connection nearest the fuel regulator is this right?
I only loosened the hose to see if it still had pressure which it did so I continued, should I go back and redo this?
BROOMY
Also I have this weird feeling it's the fuel vacuum hose ,from the throttle body, would it help if I sucked it from suck it from the throttle vaccum to the throttle bodyside would it help.?
As In the throttle body is sucking.
BROOMY
Realoem shows them the other way round but Ino I never took them off?
Hose from the fuel filter does NOT go to the pressure regulator. It goes directly to the injector fuel rail.BROOMY wrote:I tried it today all seems well but now I'm questioning did I remember which way the fuel hoses went when I put it back together.
BROOMY
All pipes were the right way round the fuel stinks n won't light .
12 year old fuel in the tank
BROOMY
Oops
BROOMY
Anyone know how to drain the tank or is it a through the fuel pump entry.
Found out the fuel is dirty
BROOMY
Now that Iv finally had time Iv found my fuel pump doesn't seem to work, where can I source one ?
iDemonix
Did you try bridging the fuel relay?
BROOMY
Exactly that .
Pins #87 and #30 right ?
If so I got nothing from the fuel outlet hose
pianist
Thought you said fuel coming through but you had your fuel lines mixed then you said fuel is 12 years old which would make it stale and you wanted to drain it, now fuel pump is not working? Maybe you need a mate that knows a thing or two about cars that can show you how to correctly follow things through before you get yourself in more bother, or if someone on here gives you steps to follow and you not sure how to get around to do them just ask and I am sure you'll get the guidance.
pianist
Maybe I came in a bit too strong there
just don't want you to make it worse thats all
BROOMY
The way I feel is the car doesn't need to run it would just be nice to talk of if it did.
I use this sight as a sorta hit n miss.
I'm actually a passed level 3 motor vehicle student, I'm saying it incase others have the same problem, of which your not helping them.
BROOMY
But like I already said it pins 30 and 87 to constant flow the fuel pump right?
blazed
pianist
Didn't want to upset you it's just when you read through your posts it sounds like fuel was coming through when you undid fuel filter pipe and then two posts latter pump isn't working so it begs a question how did you go about to check it? It is not clear.
So did you drained the fuel and is the pump buzzing?
BROOMY
I left the fuel as was and tried to bypass the relay with no outcome, the pumps currently making no noise at all.
So what do you suppose I do now?
pianist
If it was me I'd check if current is getting through to the pump by bypassing the relay again and testing pump pins with multimeter or bulb and if it does but still no buzz it's a new pump on order then
BROOMY
Thank you, I'll try this
BROOMY
Sorry about the wait, iv been on holiday for 6 weeks.
What Ino now is the car will run using carb cleaner down the plug holes.
Now I found the injectors don't seem to be firing.
Is there a way to get them to fire constantly while I check them?
What do you advise now?
12 volts will open an injector, but only apply as a pulse, or you will burn them out.
Is there power at the red/white wire at the injectors when the ignition is on?
BROOMY
Delete I didn't read sorry
BROOMY
Also a stud and 2 nuts are missing from the lower throttle body mountings.
Would this be the vaccum for fuel regulator not working from not getting enough air sucked through it.
I say this as its right next to it. Or is this not helpful?
BROOMY
What you reckon they'll have the even nuts there tomorrow?
They never have nothing there , it's a common size.
