speedos
Griffffo
hi guys again my speedo in my 323i auto has shit itself so I was wondering can you put a speedo out of an 325e into a 323i? and would it work or would it be out of calabration?
All interchangeable. Speedo counts rotations of a rear wheel, and is not intended to be accurate anyway.
The purpose of a speedo. in a car is to ensure that you do not inadvertently break any speed limits, so all indicate that you are going faster than you actually are.
Griffffo
thanks a million!Brianmoooore wrote:All interchangeable. Speedo counts rotations of a rear wheel, and is not intended to be accurate anyway.
I have checked the-
-fuse 12(fine but cleaned her up)
-diff sensor(so clean it looks brand new)
I also checked green plug and wire goes to the dash cluster and speedo and the wire had some play from the plug! could this be my problem?
If you disconnect the white plug from the instrument cluster, and connect a meter on its 'continuity' setting to pins 8 and 12 of the plug, it should indicate continuity and open circuit, in succession, several times for each turn of the rear wheels. Use short pieces of bare thin wire to push into the plug, and connect the meter probes to these.
By far the most common cause of an E30 speedo. not working is failure of the copper wire inside the loom leading to the diff. as a result of the copper becoming brittle with vibration from the diff.
Gently pull the individual wires near the diff., and if one of them stretches, you've found the problem. A length of the wire, complete with plug, must be replaced, not repaired.
Griffffo
thanks ive had the dash cluster out heaps of times so thats piss easy to do.Brianmoooore wrote:If you disconnect the white plug from the instrument cluster, and connect a meter on its 'continuity' setting to pins 8 and 12 of the plug, it should indicate continuity and open circuit, in succession, several times for each turn of the rear wheels. Use short pieces of bare thin wire to push into the plug, and connect the meter probes to these.
how far back with that wire should I search?
Griffffo
I ckecked the wire on the diff and it realy stiff and hard like you were saying it should be so whats next? could it be that single green wire and plug that goes to the back of the speedo in the cluster?Brianmoooore wrote:If you disconnect the white plug from the instrument cluster, and connect a meter on its 'continuity' setting to pins 8 and 12 of the plug, it should indicate continuity and open circuit, in succession, several times for each turn of the rear wheels. Use short pieces of bare thin wire to push into the plug, and connect the meter probes to these.
