MOT issues... 325i
oomz1975
Post Tue Apr 05, 2016 2:34 pm
Been away from the zone for a while, mainly because the car has been working 100%.
Took it for MOT this morning & found out my power steering rack has shat itself & is leaking fluid everywhere.
What is the best option for upgrading & what is required to do the job.
Secondly the car has started running like a bag of shite, coughing & bunny hopping if I try & put my foot down.
I haven't had a chance to check yet (still at work), but is there anything obvious I should be checking?
Any help will be greatly appreciated....
tristan325
Post Tue Apr 05, 2016 3:04 pm
Will the z3 rack fit? It was a common mod on the e36 etc. The coughing and bunny hopping is possibly a split intake hose or vacuum leak.
daboy3000
Post Tue Apr 05, 2016 3:43 pm
I'm no expert but i think a lot of people fit the purple tag E46 rack.
Jesus325iTouring
Frog freak !
Frog freak !
Post Tue Apr 05, 2016 5:10 pm
Unless you're a tight ass such as myself and just a manual rack for a fiver :D
ross_jsy
Post Tue Apr 05, 2016 6:35 pm
Purple tag e46 rack is the new daddy. z3 racks are still very good, but they are all old now.
DanThe sells all the conversion parts and they are superb quality
oomz1975
Post Sat Apr 09, 2016 6:43 pm
Found myself a E46 purple tag steering rack, also ordered all the conversion pipes, engine mounts & steering shaft from Danthe.
Hopefully sort a couple of E34 steering UJs too...
The rough running, I'm putting down to all the power steering fluid that has been splashed all over the engine from the failed steering rack. Certainly, the distributor cap & rotor can do with a clean up.
Post Sat Apr 09, 2016 8:24 pm
oomz1975 wrote: The rough running, I'm putting down to all the power steering fluid that has been splashed all over the engine from the failed steering rack. Certainly, the distributor cap & rotor can do with a clean up.
Optimism is an admirable trait in a person, but sadly, I doubt it will be rewarded in this case.
