Bad smell
mikelat
Post Sun Apr 03, 2016 12:52 am
When I park my e30 in the garage after driving I end up with a burnt smell for about half an hour. I have no oil leaks, the block and oil pan are perfectly dry and my rad and all the hoses are as well. The engine never overheats and when I am idling my temp gauge goes a hair over mid point and then drops below it as the fan kicks in. It is not an electrical smell and I never have to top up my fluids so I am not losing anything but I can't for the life of me figure out where it is coming from and was wondering does anyone have the same thing happen?
1990 325i Coupe Gletscherblau_Metallic
Cypriotgeeza
Post Sun Apr 03, 2016 1:17 am
Is your car a manual? :?
Check my M30 build threads:
New Daily : viewtopic.php?f=34&t=285452
mikelat
Post Sun Apr 03, 2016 1:28 am
Yes and there is a tiny seep from the selector shaft seal but it barely forms a drop a week and never marks the floor. Think that could be the issue?
Cypriotgeeza
Post Sun Apr 03, 2016 1:31 am
mikelat wrote:Yes and there is a tiny seep from the selector shaft seal but it barely forms a drop a week and never marks the floor. Think that could be the issue?
That could be slightly spraying onto your exhaust as you drive..
Where do you rest your left leg?
I have no idea on your driving habits or how much traffic you sit in etc but it could be a burnt clutch smell?
mikelat
Post Sun Apr 03, 2016 1:41 am
Definitely not a clutch smell and very little traffic driving as she is a bit of a garage queen not a dd. I rest my right leg (left hand drive) against the transmission tunnel and haven't noticed any heat from it if that could be an issue. It seems like more of a hot smell than a burnt one but with an unpleasant odour indoors.
jmc330i
Post Sun Apr 03, 2016 9:28 am
Considering your location, does your car have a cat fitted?
James
'91 325i Sport
'93 318i touring 16v
mikelat
Post Sun Apr 03, 2016 4:59 pm
Yes it does and it is the original.
Post Sun Apr 03, 2016 5:52 pm
Is it a sulphur or rotten eggs smell?
mikelat
Post Sun Apr 03, 2016 7:05 pm
Hard to say exactly but somewhat like that...can a cat do that??
Cypriotgeeza
Post Sun Apr 03, 2016 7:09 pm
mikelat wrote:Hard to say exactly but somewhat like that...can a cat do that??
Yep if its aged or if the lambda sensor is defective!
