Rear shocker top mounts!! 😡
Tombo
Post Wed Mar 23, 2016 4:54 pm
What's going on?! My e30 318is has had two sets of these and they only last about 6 months before there nackerd!!
Does anyone know anything about this? Heard that I could put e30 m3 cab ones on?
Topblag
Post Wed Mar 23, 2016 4:59 pm
They should last longer, e46 M3 top mounts are the best to buy. Is your rear end polybushed or very low ?
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Tombo
Post Wed Mar 23, 2016 5:08 pm
No all standard. Will the E46 m3 top mounts fit strait on?
blazed
Post Wed Mar 23, 2016 5:10 pm
Have you got both cupped washers fitted? Part number 6 & 12 on this link. http://www.realoem.com/bmw/enUS/showpar ... Id=33_0325
I have used meyle HD top mounts sold as fitting e46, e36 and e30 on several cars and all are still good.
Tombo
Post Wed Mar 23, 2016 5:14 pm
I'll have a look into it, mechanic did the job.
blazed
Post Wed Mar 23, 2016 5:16 pm
In what way have they failed? Has the damper pushed through?
Tombo
Post Wed Mar 23, 2016 6:13 pm
The rubbers are both fu@ked and knocking when I drive now. I'll try and get some pics.
Post Wed Mar 23, 2016 7:36 pm
Are they OEM items (Lemforder or similar) or some cheap spanish jank from the euro car parts "tesco value" range? If the latter you are doing well to get 6 months out of a pair.
Post Wed Mar 23, 2016 7:54 pm
blazed wrote:Have you got both cupped washers fitted? Part number 6 & 12 on this link. http://www.realoem.com/bmw/enUS/showpar ... Id=33_0325
On OE E30 dampers, these washers are part of the dust covers. I've seen many cases of failed nearly new top mounts, and all have been caused by replacement dampers that don't have the washers built in, coupled with failure to fit external ones.
HairyScreech
Post Wed Mar 23, 2016 8:47 pm
Lemforder Z3 topmounts are the same as E46 m3 ones and half the price.
Its possible Lemforder may now only make the improved e46 style mounts.
Tombo
Post Fri Mar 25, 2016 4:27 pm
Ok just stripped the boot liner out and uploaded the pics of the top mounts, you can see where all the rubber has collected on the boot floor.
http://s1104.photobucket.com/user/Tombo ... sort=3&o=0
blazed
Post Fri Mar 25, 2016 5:14 pm
I would say you are missing the lower spreader washer. Here's a link to the wiki page it shows the washer in the top of the dust cover. http://www.e30zone.net/e30zonewiki/inde ... Top_Mounts
Post Fri Mar 25, 2016 7:37 pm
blazed wrote:I would say you are missing the lower spreader washer.
Not so sure of that, now I've seen pics. Looks like the whole rubber has been pushed out.
What's the ride height of the rear of this car?
Tombo
Post Fri Mar 25, 2016 8:13 pm
Standard
Tombo
Post Sat Mar 26, 2016 10:46 am
They need doing soon as, what would be the best replacement then?
BenHar
Post Sat Mar 26, 2016 1:06 pm
Post Sat Mar 26, 2016 2:03 pm
Always remove the bottom damper bolt, where it connects to the trailing arm, and remove and refit the damper complete with top mount completely fitted.
There should be a paper gasket for the top mount, which isn't shown in the wiki guide, but a smear of seam sealer will do.
When refitting the damper bottom end to the trailing arm, leave the bolt loose until the car is back on the ground and at ride height, before finally tightening the bolt.
The damper limits the suspension droop when the wheels are off the ground, so when the dampers are off, try not to let the trailing arms hang right down - it stresses the driveshafts.
Note which way the cupped washers should be - curved away from the mount.
Tombo
Post Sat Mar 26, 2016 11:25 pm
Thanks for your help everyone.
Post Tue Mar 29, 2016 1:04 pm
Brianmoooore wrote:When refitting the damper bottom end to the trailing arm, leave the bolt loose until the car is back on the ground and at ride height, before finally tightening the bolt.
More than likely a dumb question Brian but why not tighten these up before lowering to the ground?
Cheers Mart
Post Tue Mar 29, 2016 1:20 pm
Because the lower damper mounts would be permanently twisted.
Post Fri Apr 01, 2016 3:37 pm
Brianmoooore wrote:Because the lower damper mounts would be permanently twisted.
Makes sense now cheers.
P_VIDDY
Post Sun Apr 03, 2016 4:38 pm
E46 powerflex ones fit well
Post Sun Apr 03, 2016 6:22 pm
