The items were rear shelf / speaker covers. The description said one had minor surface corrosion. This would be under the vinyl covering where the speaker mounts
Ok, it's not a visable area and I can alway clean it up can't i......
This is what turned up
Surface corrosion ? The metal is that bad it's broken away !!
Sent them an email expressing my concerns, didn't ask for anything in terms of a refund in the initial email
My email ”¦.................
Hi
Order received today, thank you
However upon inspection or the items one of them has quite bad corrosion.
It can be dealt with and as it on the underside it's hidden but it's not ideal
I've attached photos
Kos
Their reply.........
Hi Kos
We did advise this in our listing. At the bottom of every picture is a description of any defects when we receive the items in. Thuis is what it stated: -
Slight corrosion on grid on the inside.
Picture is of actual part type in stock. Most parts are supplied in genuine BMW & Mini packaging.
We did inspect and it does not effect the top view o f the part.
Kind regards
Surface corrosion ??
They did offer a refund in a follow up email but the problem for me is as follows. I needed them and didn't want to wait for a back order from Germany to arrive which can take 10 days. Trim shop needed them by Saturday.
What really annoyed me was as follows
1-poor description
2-no apology
3-very dismissive
The apology only came after I promoted them. The email exchange continued and I will publish it just so everything is out in the open
The point is, if you do use them make sure you get clear photos of the parts you order because if it's not as expected, don't expect any help from them let alone an apology.
I for one will not be using them again.
