correct blue temp sensor?
jurassicwadey
my m30b35 engine runs rough on first start up until warm, and as per a previous thread, i was advised it might be the blue temp sensor, have looked on line to purchase a new one but I'm a little unsure as I don't know which year my engine is? is that relevant? or is any sensor for the e34 be suffice?
The same sensor is used across many BMWs and other makes.
Beware of cheap sensors from a land a few thousand miles away. They will be correct at a couple of temperatures, but don't 'track' properly between the two.
dimebag_from_hell
Is a rough start up the classic sign of a dud blue temp sensor or could very poor mpg alone be a sign?
thanks
thanks
jurassicwadey
OK, so drove my 30 to the bodyshop yesterday- seemed a little hesitant at times, would the blue temp sensor be the cause for that as well?
Have ordered a new blue temp sensor, so time will tell!!
andysheep
Iv got this problem
did you go to the stealers or is there a cheaper option?for the blue temp switch.....
dimebag_from_hell
How much is it from the stealers?
andysheep
I havnt got the balls to check cos i need two,one for my driver and one to replace the one i robbed out the miss's cabby
jurassicwadey
well the blue temp sensor didn't work for me- so i have a spare one!
andysheep
Come on then pm me the bad news,iv just thought even when i bleed the brakes and top up fluids it still not going to start with the duff one i stuck in the hole for window dressing
thats if you want to pass it on?,oh i have a exhast gasket set if your in need ,bmw one part number11 62 1 723 656,no good to me i aint got a big dog m30 engine,mine are m20b20 ×4 and 1 m10,andy
Ps whats your plan now that fix didnt work
jurassicwadey
well i disconnected all the connectors in the engine bay, cleaned them all off and plugged them back in- seems to be running better?
but it is booked in with a specialist near me who is going to check it over, check the timing etc etc
will pm you regarding the sensor
jurassicwadey
well that embarrassing moment when they the specialist fixes your running problem in 30 seconds!
the fault was the earth! I hadn't noticed that the terminal connection on the battery was loose!
but on the bright side as id driven it there, i let him take the car in and fully inspect it, he found a few little niggles but on the whole seems all good! phew!
can at least drive the car with a bit more confidence now!
andysheep
Not nice when things arnt queit right,buggs you in the back off your mind.nice to hear its sorted,
