Hi everyone,
Can anybody tell me if fritz bits T304 M20 exhaust manifold will fit an e30 fitted with an e36 steering rack?.
They are unsure themselves!
All help appreciated!
Fritz bits manifold compatibility (e36 rack)
svenga
jmc330i
That should answer your question.svenga wrote: They are unsure themselves!
The manifold also isn't any better than the standard M20 manifold in terms of performance gains.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
NO!
Not unless you use some solid engine mounts which raise the engine to the point that you can't use a fan shroud and the engine vibrations are sent thought the car.
svenga
Thank you kindly guys!
I think I will just stick to downpipe back.
