Temp guage
drai
Post Sun Feb 28, 2016 3:45 pm
Can somebody tell me where is the best place to fit a temp sensor for a accurate reading on a m20 2.5 engine. I've purchased a fitting for the oil pressure sensor from lma. Any photos and advice would be appreciated.
KW355
Post Sun Feb 28, 2016 4:29 pm
oil or water ?
drai
Post Sun Feb 28, 2016 5:24 pm
oil
steve_k
Post Sun Feb 28, 2016 6:01 pm
drai
Post Mon Feb 29, 2016 1:16 pm
the info is incorrect I think ?l can fit the oil pressure switch in the side of t fitting from lma but can't fit the temp sensor due to its length. I also thought should fit original pressure switch bottom of fitting. To get a accurate read the temp sensor should be in the flow of oil. What have other done when installing the temp sensor can it be fitted to the sump?
steve_k
Post Mon Feb 29, 2016 6:51 pm
don't fit the temp sensor in the sump it will give a false reading,
when i fitted mine i used the long LMA T piece with the pressure sensor mounted on the side & for the temp sensor i used this \/\/\/\/\/\/
http://www.ebay.co.uk/itm/201108485737? ... EBIDX%3AIT
with the short LMA adaptor, true it is at the bottom but it is in the flow of oil & give a true reading.
i take it you are using VDO gauges??
drai
Post Tue Mar 01, 2016 10:44 am
Thanks for info I'm using black line gauges from demo tweaks I may look into a fitting the sits between oil fitter anybody any experience with theses
