Anyone using these ? They seem good value as SKF is a good brand and much used by BMW.
http://www.mister-auto.co.uk/en/drive-s ... !1148.html
SKF replacement driveshafts
BMG
motormanmick
Hello BMG, page loads but no info, in my line of work, I used bearings of all brands/sizes/types and SKF is one of the best, if its good value and BMW use it, that's good enough for me. cheers.
BMG
Sorry, should have checked the link. For some reason it is shortening it and missing the last part.
Anyway, it's SKF part number VKJC 1148 at £73 each
I just went through the system to find drive shafts and they are showing as out of stock, brand is Spidan
BMG
Not sure I follow. You mean the Mr Auto site ? They show SKF brand in stock at £73 each.DanThe wrote:I just went through the system to find drive shafts and they are showing as out of stock, brand is Spidan
Was wondering if anyone has fitted them or any thought before I maybe buy.
HairyScreech
I thought gkn had stopped producing the joints and all shafts were now remanufactured items?
Could be wrong though as the compact and Z3 use the same joints, it would leave an awful lot of cars out in the rain.
bigbird76
BMG have you bit the bullet and bought a pair? If so report back please....
Leigh
Leigh
BMG
I haven't yet. I found a link to a German E30 site which seemed to be saying Mister Auto keeps advertising these at a tempting price and then cancels on you saying they are not available.bigbird76 wrote:BMG have you bit the bullet and bought a pair? If so report back please....
Leigh
Also on the same site, there is talk about a dimension difference and alignment of the ABS ring.
I pulled my driveshafts apart the other day and got the cap of the outer CV joint in a way I could reuse it ( they don't seem available to buy ) and re-crimp it if needed. There was less wear than I was expecting. If anything, it is the inner joints that show the most wear, so now thinking of just replacing those and cleaning up the rest.
bigbird76
Ok cheers for that
Leigh
Leigh
BMG
This was the link.
http://e30-talk.com/topic/111956-halbac ... -erneuern/
