The plastic clips that holder the steel fuel breather pipe from the charcoal canister to under the rear seat, I got p/n 16131177490 but appear from a quick Google to be NLA with no alternative offered.
Also, I don't see the p/n for the same style clip ( am assuming it's different due to pipe size differences between brake and fuel ) that holds the brake line in place as leaves the floor pan to go around the fuel pump and into the under seat area. I assume they are the same as those holding the brake lines on the swing arm of 34301161567 which also seems NLA ?
Part number help please
motormanmick
16131177490 is superseded by part no 16131177494
34301161567 found available on ebay, link below and elsewhere, cheers.
http://www.ebay.co.uk/itm/BMW-BRAKE-PIP ... 0994493223
BMG
Many thanks!
