rear tail panel
SHAKEELE30
- Boost Junkie
i found this part number for the rear tail panel 41348103088, wondering if this is the only part number and if its available from dealers. i was told theres also another part number but i can only find one, anyone have any info on this?
also after the rear battery tray section, but cant find it on the realoem, but recall someone posting it on facebook e30zone, but no price or part number, anyone have an idea?
thanks
thanks
BenHar
Pre or post facelift?
Ben
Ben
SHAKEELE30
- Boost Junkie
Facelift
BenHar
SHAKEELE30
- Boost Junkie
this is the other part number i was given by cotswold
http://www.realoem.com/bmw/enUS/showpar ... 1341961508
anyone have an idea what the difference is and why
Mitchen
Just got one of these today. Weird how mine is a saloon 320i and yet has completely different part numbers despite having the same shell
SHAKEELE30
- Boost Junkie
Which part number did you get and do you know the difference between them
Single and dual pipe exhaust 'cut out'?
SHAKEELE30
- Boost Junkie
Oooohhh, any idea how to find out which one is which?
Thanks for that
Thanks for that
Do the "found on the following vehicles" search, and see exactly what models each version was used on.
Mitchen
Nope, mine has the cut out for 2 pipes as well.Brianmoooore wrote:Single and dual pipe exhaust 'cut out'?
SHAKEELE30
- Boost Junkie
Dont 320s and 325s both have twin pipes, the 2nd link says its for 320, and the first link for 325..
Mitchen
The part number situation for rear panels is very strange.. me and the parts guys at cotswolds tried to figure it out earlier this week, and we were stumped.. There's loads of different part numbers i.e. 5 different part numbers for a twin exhaust 320i... and you can't see why there would be any difference whatsoever between part numbers.
Just go on RealOem.. enter your VIN and use the part number it's telling you on there.. There's probably about 10 other part numbers which will all give you an identical panel, but better to be safe than sorry.
Tiniest difference will generate a different part number. Possibly variations in number plate fixing holes?
SHAKEELE30
- Boost Junkie
i thought they would be all the same for all models, but guess not...
