V10 M3 acceleration short vid
KW355
Hopefully this will open in another window.
Third and fourth gear acceleration, all done in a politically correct environment under close adult supervision.
http://vid292.photobucket.com/albums/mm ... mwbnzd.mp4
Jon_Bmw
- Dangerous when thinking
Relentless!
maxfield
The speedo moves as fast as the Rev counter
KW355
It was not until I watched the video that I realised it takes about the same time to get through third and fourth gear, it still accelerates the same in fifth gear
glenn
- Engine Transplant Services
it looks to me like its about 3 seconds from when you hit the throttle @ 60, to 100?
jimbom30cab
- Tech 1 freak
Immense !
Jesus325iTouring
- Frog freak !
318is is quicker, baby M3 innit.
holy f**k thats quick
I bet your brakes are shitting themselves
KW355
Probably Dan, I know I was !DanThe wrote:I bet your brakes are shitting themselves
Kos
fuck
JungleGus
115-130: WOW
ajay
The oil temp is just about ok to give it some...does go well! a˜Ž
KW355
I read the oil temp off the vent gauge, I always warm a car up before using the performance.ajay wrote:The oil temp is just about ok to give it some...does go well! a˜Ž
The oil temperature gauge in the Rev counter is connected to the gearbox, it normally runs at about 50 degrees Celsius
