Help withFitting Bc coilover 318is 45mm strut for first time
Brendy318is
Post Sun Sep 20, 2015 8:13 pm
Recently bought first e30 318is also bought bc coilovers and in the instructions shows a "spindle" that's sapost to come from the original strut and inserted into the coilover then welded?.. I'm not to sure on what they mean as haven't worked on e30 before,, do I take out the strut complete out of the hub and insert the coilover and weld round or do I have to take piece of the original strut? Anyone do this before and if so any pictures? Cheers any help be appreciated
ross_jsy
Post Sun Sep 20, 2015 8:48 pm
A 318iS will have 51mm struts.
Remove the damper from the strut housing, cut it down and weld on the body of the coilover. I believe you can remove the damper from the coilover body on BC's. Do that otherwise you will ruin the shock.
I'm sure someone will be along with pictures soon
Brendy318is
Post Tue Sep 22, 2015 4:58 pm
I read it was a 45mm strut, do I just measure the size of the strut body itself to find out? I take it that's what they mean by 45mm?bcheers
ross_jsy
Post Tue Sep 22, 2015 8:15 pm
318iS's left the factory with 51mm struts:
http://www.e30zone.net/e30zonewiki/index.php/318iS
Yes you can measure the strut housing
