How hot is too hot?
m_jermyn
Post Thu Aug 27, 2015 11:18 am
How hot is too hot?
So I can see my temp through the ecu software and I can set a alarm to warn me if its getting to hot.. How hot is to hot?
I did a coolant swap and its now reaching 3/4 on the car gauge at traffic lights and the software tells me its 95 deg C.
Before coolant swap it would go past half way...
Guess I may have a air lock?
Post Thu Aug 27, 2015 4:22 pm
yup i'd not be running an M20 in the aussie heat if it had an air lock. Looking for trouble!
m_jermyn
Post Thu Aug 27, 2015 9:31 pm
Well it's only 20 deg C at the moment... But what is actually considered hot, is 95 hot?
Post Thu Aug 27, 2015 10:21 pm
95 is more than the thermostat which is 88° or if your car is prepared for hot climate or air con then 80°
Personally I don't like to see the temp gauge needle above half way
m_jermyn
Post Fri Aug 28, 2015 11:27 am
Thanks guys..
BenHar
Post Fri Aug 28, 2015 3:48 pm
Thermostat for an M20 engine should be 82 degrees and the needle should sit just above the quarter mark.
Ben
