Sprayer
yaad
Post Sun Aug 16, 2015 11:48 pm
Just had all my car welded where needed and dents all around filled up. Looking to get it primed within next month then block down and sand myself and then painted around end of year (will be in dry garage between primer and final paint). And also got the mtech2 kit fitted. Anyone know a good trusted place in/around romford essex?
Any advice would help
Yaad
powelly
Post Mon Aug 17, 2015 9:48 am
Leaving a car sitting in primer is a bad idea. Primer is a porous product and will absorb moisture, you will likely see the results of this in you fresh paint as little micro blisters, epoxy primer is one product you can use.
Image Le Mans Classic 2006
HairyScreech
Post Wed Aug 19, 2015 6:52 pm
As said, there are epoxy primers that can be rolled on that are 100% waterproof and brilliant for this kind of thing.
Developed for marine use and almost literally bullet proof.
