Plastic trim name
Sonatine
Post Sat Aug 15, 2015 1:32 pm
What is the panel of trim under the steering wheel called?
It came loose this morning and my foot was wedged stuck on the clutch pedal at a roundabout. After some stalling and kanagaroo hopping I made it to a side road, but had to rip it off in break it in the process :roll:
Cheers.
Post Sat Aug 15, 2015 1:51 pm
Expensive is what it's called ! Otherwise known as an under dash 'knee roll' . Several different variations, used between £25 -£75 . New £75 + £3 for all the correct clips . I bet you won't be so brutal next time ! :)
zd3bx
Post Sat Aug 15, 2015 4:24 pm
Here's a good article to make sure you fit the replacement properly > http://blog.bavauto.com/5514/1987-bmw-e ... or-mounts/
Mitchen
Post Sat Aug 15, 2015 5:08 pm
pacerpete wrote:Expensive is what it's called ! Otherwise known as an under dash 'knee roll' . Several different variations, used between £25 -£75 . New £75 + £3 for all the correct clips . I bet you won't be so brutal next time ! :)
Now NLA
1990 320i Coupe SE
viewtopic.php?t=253048
Post Sat Aug 15, 2015 5:51 pm
Now NLA
Awesome ! :D Loads of good used ones here from useable to MINT ! :)
Mitchen
Post Sat Aug 15, 2015 5:58 pm
Save me a mint anthracite one please :wink:
1990 320i Coupe SE
Sonatine
Post Sat Aug 15, 2015 6:26 pm
Sure I can remember under dash knee roll. Easier than some obscure Latin/medical/dinosaur name. Are the variations related to model/year?
Thanks for the link zd3bx very helpful.
