As some of you might know I have a long term project on my hands, at the minute I'm looking at doing a bit of wiring.
The plan is to hide most of the wiring from around the bay which means I'm extending wires and rerouting them a little bit. Problem is one it's done it will be, not impossible, but difficult to get at the wiring so in tryingI to make sure I have it all worked out before I'm at the point of no return.
So far the wiring I know of that I'm rerouting is this
Headlights
Fogs
Horns
Heated washer jets
Washer pump wiring
Temp sensor and fan loom wiring
Abs (think these are long enough to be left alone)
Brake pad sensor
Headlight washer
What way does the wiring for the obc temp sensor run, doors it normally make up party of the loom that was with the wires for the lights?
That's all I can think of, am I missing anything?
Engine bay wiring
Jozi
