b4 bilsteins
rotta
Post Thu Jul 16, 2015 9:28 am
best place to get the above (b4 bilsteins) 45mm (318i) fleabay??
many thanks
Rotta
griff87
Post Thu Jul 16, 2015 9:45 am
http://www.ebay.co.uk/itm/Bilstein-B4-F ... 462b854219
Best= Cheapest? Its probably here, but be sure to check the item carefully as Demon Tweeks have a habit of sending the wrong part, I had 45mm sent instead of 51mm which had to go back. I was also missing one shock collar nut. They get confused by 45mm, 51mm, 325i, cab and touring.
Delivery guy who collected my struts for the return said he lost count of the amount of demon tweeks stuff he had to collect! You should be OK with a 318i unless its a touring or cab.
rotta
Post Thu Jul 16, 2015 12:11 pm
its a moor door so i should be ok! :)
tom325sport
Post Thu Jul 16, 2015 5:36 pm
Got mine delivered from Demon Tweeks. No problems but make sure they come with the locking collar nuts. On their website there is 4 types of B4 shock for the E30. One is the rear, one is for 45mm struts, one is for 51mm struts and the other is for 4X4 e30's.
