Gearbox Oil - Getrag 260
PG325
Post Sun Jul 12, 2015 3:54 pm
I've got quite a loud layshaft noise once the cars been ran up to temp but pretty quiet when cold.
I don't use the car apart from in the summer months so was wondering a thicker viscosity gear oil would benefit.
I recall changing the gearbox oil about 5 years ago with some cheap 75w/90.
Any recommendations about something which may quieten it down when hot?
**BANNED**
Post Sun Jul 12, 2015 5:56 pm
Usual grumble regarding gearbox's is that the change is stiff and heavy when cold,fixed by using ATF instead of gear oil....but I guess that will not help you much! :D
However,gearbox's like to see clean oil every couple of years or so,it should be every inspection 2,as this removes the water that the oil collects via condensation.
So I would suggest that a decent quality 75w/90,swapped more fequently,will help a bit.
Youth is wasted on the young.
