Hey all,
Just bought a 1987 E30 320i SE. It's all original and all parts seems to be original.
Never been restored or repaired properly so suffering some old age related damage, however the shell and interior is in relatively good condition...
Wanted to get some advice where should I start and what are main issues a 1987 E30 would most likely have.
Haven't done proper inspection yet, however current issues are:
- Brake light indicated worn brakes is on
- Prop shaft seems to have something loose, as when clutch released from gear there's a clunk sound from underneath the car
- Diagnostics console next to rear view mirror is dead
- Traces of oil all over the engine and underneath the gearbox
- Rev counter does not work
What main areas should I check and expect to be worn?
Thanks for help
New to e30. Need advice.
ross_jsy
Hi and welcome to the forum.
Your main issue will be rot, everything else is easy enough to sort out. Have a good look in all these areas:
http://www.e30zone.net/e30zonewiki/index.php/Rust
And as with any old car, bushes are going to be in need of replacement if they haven't been done recently. Use quality rubber from the likes of Lemforder
bosers
Chroist! That's a depressing read, Ross! I prefer to leave a protective coat of mud on mine.
Topblag
Oil leaks are good, keep the rot at bay.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
e30aniac
Thanks guys. I will get on it.
Cypriotgeeza
Sounds like its either Prop shaft backlash or the rubber guibo or "donut" as some like to call it is knackerede30aniac wrote:
Check my M30 build threads:
e30aniac
Are the guibo or prop shaft backlash problems repairable on regular stands in the garage?
Cypriotgeeza
The beauty of these cars is that with the right tools ANYTHING is repairable on regular stands in the garagee30aniac wrote:Are the guibo or prop shaft backlash problems repairable on regular stands in the garage?
Also check the centre bearing while your there..if it hasn't been change yet id recommend doing that while your at it
